01 Civic LX brake light issues
Old 01-13-2014
ProAc_Fan's Avatar
ProAc_Fan is an unknown quantity at this point
Come to find out both corner brake lights not functioning. However the spoiler mounted brake light IS working. Cruise control also not working. The fuse is fine. I replaced the brake light switch but that didn't solve the problem. Where do I go from here ?
TIA
Mike
Old 01-13-2014
CraigW's Avatar
Re: 01 Civic LX brake light issues
Brake bulbs X 2
If any work your switch is fine.
Old 01-14-2014
ProAc_Fan's Avatar
Bulbs were already replaced. The 4 way flashers work so I know the bulbs are fine.Also burnt out bulbs wouldn't explain the cruise control malfunctioning. Something else is going on I just need to know where to look.
Old 01-14-2014
CraigW's Avatar
Your turn signals are separate bulbs and circuit. Signals are single filament. Brake/Tail are dual filament.
If tails are working (same bulb) then check for voltage when brakes applied at the socket and work your way back to 3 way junction point. Wire color = WHT W/BLK stripe.
The sharp tip of a 12 volt test light will allow you to pierce insulation of wires.
Old 01-14-2014
ProAc_Fan's Avatar
That junction is located in the drivers side rear side panel?
Mike
Old 01-14-2014
CraigW's Avatar
Don't have the ETM handy for the 7th gens.... but would imagine it would be in the rear area.
When I had the broken wire leading to markers & license lights on the trunk it was all on the passenger side
The 8th gens show it as near the C pillar.
Old 01-14-2014
CraigW's Avatar
From ETM, Connector 601 = 14 Pin, Gray housing, Right C pillar (coupe similar)
Old 01-16-2014
ProAc_Fan's Avatar
Not to sound dense, but by right C pillar do you mean driver or passenger side?
Mike
Old 01-16-2014
CraigW's Avatar
Passenger, find the black plastic loom wiring cover affixed to trunk and hinge arm and follow it forward.
Xuhme
21
08-07-2023 03:40 PM
McD
04-29-2015 03:50 PM
civic_gt
04-19-2015 08:15 AM
ashleymmackey
04-18-2015 09:48 PM
Quick Reply: 01 Civic LX brake light issues
