crank no start
Rep Power: 0 crank no start
My civic wornt start. i checked the timing 3 times. There is fuel pressure at the fuel rail. My c.o.p. are getting 12 volts.I have compression 110 psi. I just did the head gasket and had the head resufaced, now it cranks but wont start, doesnt even attempt to start. I also adjusted the rockers to spec.The check engine light will turn on when i put the key in and turn it to ignition. stays on for 20sec. then flashes 5 times and turns off. Once i turn the key to start the car it cranks but no start. When I turn the key back to ignition the check engine light is off and the battery light is on. I have tried everything i can this of......any ideas??
Re: crank no start
Cam timing off by a couple teeth? How did you check?
Did you get all of the wiring reinstalled correctly? Even the ground wires on top of the thermostat housing?
Any codes?
Re: crank no start
unable to start
tripple checked everything and had my partner check as well
For an engine to run, it needs spark, fuel, and compression...in the correct amounts, and at the correct times.
How did you check that there is spark?
How did you check that there is fuel being squirted from the injectors?
What has been done to correct the super low compression readings?
If you suspect IAT or Cam sensor, unplug them and try it.
Wild Cranker
427
01-28-2016 06:49 PM
black2k1vtec
12-06-2001 09:49 PM
