Window fell into door and is stuck
Rep Power: 0 Window fell into door and is stuck
Today i was driving my 03' Honda Civic LX and the window slowly fell down into the door, later i looked it up online and i found out that it could be as simple as the fuse, but that was not the case. The window fell on its own and when the button is used there is no sound of any kind, i think it is dead.
What i am wondering is what this could be this is my first time posting and i do not know what kind of help you guys could give but i was wondering if you guys could tell me what you think, window regulator or motor or anything else i dont know about.
Re: Window fell into door and is stuck
You will have to pull your door panel off to figure out what happened.
My guess is the regulator cable broke.
Rep Power: 0 Re: Window fell into door and is stuck
i did already and i could not tell what the problem was. is there a way that i could? and if it is the cable wouldnt the motor still try and raise the windor instead of doing nothing
Can you raise and lower the glass by hand?
If so, then the regulator is shot, for whatever reason.
Usually the cable breaks.
Usually when a cable breaks, the motor makes awful crunching noises when you try it. Not always though.
JustaRhymez
General 7th Gen
07-10-2015 07:12 AM
1khilari
07-09-2015 08:12 PM
ballmich
07-09-2015 11:59 AM
