p1456 and shutting off while driving. please help.
Rep Power: 0 p1456 and shutting off while driving. please help.
So, my CEL came on a little while back, right I just had the head rebuilt to replace the valves. I took it back, and the code p1456 came up. He told me to replace the gas cap. So I've ordered one and it's on the way. But it's running like crap, worse and worse every day. It's chugging while I am idling, but even feels like it a lil while driving. It sounded like it's about to stall when I would be stopped. Now this morning, it actually did stall while I was in the middle of driving, a couple of times. It'll start back up luckily, but afraid to make any long trips if its gonna keep getting worse. So frustrated since I just dropped a grip rebuilding the head and it is running worse than before. My gas mileage is getting worse too.
And I don't know if it's related but my check oil light keeps coming on and off lately too. I'll check it and it will be super low. I just added oil two weeks ago and it's low again. It's using up tons of oil now, and its not leaking on the ground, so I guess it's burning it? If anyone has any insight, I'd appreciate it. Anything I can fix myself or do I need to pay and arm and leg to take it back to the shop?
Thanks.
Thanks.
Re: p1456 and shutting off while driving. please help.
i think you need to provide more information,
explain in detail the past history of the car, what break downs occured, and what repairs have been done and when
Rep Power: 0 Re: p1456 and shutting off while driving. please help.
I've had about a year, the head needed to be rebuilt when the CEL came on and I had it checked out by a few different shops. They found the valves to be bad... But it never broke down, it just had low compression. It did burn oil a little before, but nothing as bad as now. And the p1456 never came up before until after I got it back from the shop for the rebuild. What else do u need to know? It's a 99 Honda civic lx, 5 speed...
I just find it hard to believe all this would be caused by a gas cap. But then again, I'm no expert. My bf says it's cuz I use cheap gas, but I've used cheap gas for over 10 years, every car and never had a problem before...
Replace replace timing belt, balance shaft belt, idler pulleys, water pump, lower timing belt cover , air conditioner alternator drive belt, camshaft and crankshaft seals replaced, VVT solenoids, front motor mount spark plugs, coolant was replaced and installed with water pump system was checked for leaks none found. Oil was topped off with no leaks found, fuel gauge was checked and we connected and now operates it was stuck at one point. But here recently I think the rear main seal is leaking now I didn't replace that because we do not take the motor out of the car.The driver door actuater,is locked and I can't open it. Cars been cutting out over the last 3mon. I thought it was the battery corrioted and it was cleaned/ terminal
Its gotten alot worse. It happened 5times today. I can let it sit for 10/20min. And it'll start up again. Really frustrated and concerned. I have to get on the highway every day to get to work, and I break down every day.SUCKS!!!
Last edited by Colin42; 06-20-2019 at 06:11 AM. Reason: Removed bolding and strike through to make post legible
Received 1,122 Likes
Rep Power: 190 Re: p1456 and shutting off while driving. please help.
What does the car do when it shuts off?
Does it act like you turned the key off?
Like it runs out of gas?
Any lights on the dash? Gauges showing abnormal readings?
Sure sounds like a failing crankshaft sensor., I expect if you could get list of “ALL” the codes the ECU has stored you will have more than just a 1456 because that will not shut down the car.
You can remove the door panel with the door locked shut, it’s not pretty as your going to want extra hand or two pulling up from the outside but basically your going to pull it off the clips, taking driver seat out makes access way easier..
Only once did I have a actuator that was completely jammed,, had to get primitive on it until it was in enough pieces....
Yes, it's like I just turned the key off. When it happens the Speedo and the Tach fling to the right and dies. Then it won't start for 10/20 min.. it just cranks and don't start like it's not getting fuel or no spark. Engine light on and. brake light as well
bad ignition switch possibly? do testing before just throwing parts at it
theRedhatch
12-27-2019 04:04 PM
civicced
11-12-2012 12:17 AM
Dticalman01
02-17-2004 05:19 PM
