Help,camshaft positioning sensor, misfires, catalyst error codes
Rep Power: 0 Help,camshaft positioning sensor, misfires, catalyst error codes
Ive got a 2002 honda civic si, 147k miles on it. Ive owned it for a year and have had no problems until last week. Every now and again it just wont start. Ill turn the key, doesnt even turn over, just a click and thats it. Battery is good, lights dont dim. Negative terminal was loose, tightened it up, and the problem went away.
A day later the check engine light came on so i ran the codes and its showing 3 different misfires, a camshaft positioning sensor code, and a catalyst code. Did some reading up on similar codes and combos, but all talk about car dying, crazy idles, tach jumps, knocking, ect...but my vehicle is not giving me any serious problems at all. Theres no knocking, sputtering, grinding. Its not stalling or dying. It runs great, still getting good gas mileage. No leaks. I cleared the codes not really knowing the possible severity of the issue. Im wanting to say i need to replace the cam positioning sensor which probably went bad and is throwing all the other codes, but i hear if i dont replace it it could cause sever damage and cost me more money then the car is worth like killing the cat converter, my coils and plugs, even blow my motor...any ideas? i could really use some help. Its my daily driver and the only vehicle my wife and 1 year old daughter have and i cant afford to lose it. Mechs wanna charge me $100 for the diag and say the fix could cost thousands. please help
Re: Help,camshaft positioning sensor, misfires, catalyst error codes
First: What engine is this?
Post the actual code numbers.
Misfires can kill a cat in a matter of minutes if severe enough.
Can you feel it when it misfires? Would you even know if it was misfiring?
You cleared the codes, did they return? Which ones?
Rep Power: 0 Re: Help,camshaft positioning sensor, misfires, catalyst error codes
Codes have not come back, cannot feel misfires or anything odd, everything feels fine. I assuming its just the sensor. Passed smog no issues
Flipg123
05-08-2015 01:15 PM
davidpaustin
05-07-2015 05:08 PM
davidpaustin
04-30-2015 11:20 PM
Blaster30
04-22-2015 12:21 PM
