Is it a suspension problem if the grating sound can be reproduce during turns / bends
Old 02-25-2013
internalaudit's Avatar
internalaudit is an unknown quantity at this point
Question Is it a suspension problem if the grating sound can be reproduce during turns / bends
On sharp turns (>45 degrees) / curves at >60 km/h, one of my passenger noticed a grating sound coming from the rear passenger side (close to where the tire/wheel is).
Does the sound point to a suspension problem? I can't reproduce the sound when turning at slower speeds or less sharp turns.
How critical is it to get fixed if it's a suspension problem? I was told by my mechanic there is a slow leak on my 02 Civic's suspension a year or so ago but said it didn't pose any safety concerns.
Thanks in advance.
Old 02-26-2013
mikey1's Avatar
Re: Is it a suspension problem if the grating sound can be reproduce during turns / b
probably nothing to do with the suspension....
wheel bearing or C/V joint would be my guess
Old 02-26-2013
Thanks Mikey1. I'll bring this up with the mechanic when have the oil change done.
I went on reading a few websites/blogs and noted that the CV joints will be located in the front for my vehicle though.
If the sound is coming from the rear passenger wheel area, I'm hoping it's just a wheel bearing which may cost less to replace:
http://answers.yahoo.com/question/in...1213036AAdZxcd
Old 02-26-2013
fusion158's Avatar
fusion158 is an unknown quantity at this point
Yes, the cv joints are at the front. I would suspect ball bearing too, however since you mention a leak it could possibly be the rear shock is failed and needs replacing. Does the sound happen only when turning left or right or does it happen for both directions. Look at see if you can see any sign of the tire rubbing against the car too.
Old 02-26-2013
Thanks for your help Fusion158. We just noticed it last night, so I'll try to confirm whether turning both left and right leads to the sound though the noise only comes from the rear passenger tire area. I don't have the car lowered but I'll check if there is rubbing against the car.
Dorval Andre
General 7th Gen
28
07-21-2022 05:53 PM
edgenet
05-02-2015 08:00 PM
Dorval Andre
05-01-2015 09:37 AM
GH04si
04-15-2015 08:13 PM
supercivic01
South
11-30-2001 11:27 AM
Quick Reply: Is it a suspension problem if the grating sound can be reproduce during turns / bends
