Help! 1.7 Timing prolems
Old Jun 27, 2012
Biker Bob's Avatar
Biker Bob is an unknown quantity at this point
04 1.7 SOHC. Timing tensionor broke, grenaded valves. Had the head rebuilt, installed it today in accordance with instructions (UP on cam pulley, marks even with head, mark on stator lined up on crank with keyway up, etc) but the car still wont run.
My question is, is it possible to be 360' off on my crank position? Im thinking that the crank keyway up on one rotation is the exhaust stroke, up on the next rotation is compression. Is this the possible? Thanks for the help!!
Old Jun 27, 2012
Re: Help! 1.7 Timing prolems
No; UNpossible. 2:1 drive ratio between the crank and cam.
Spin the crank twice for every one turn of the cam.
Make sure you spin it counterclockwise if you do.
PCM can shut it down if the cam timing is off too. Recheck your marks.
Plugs wet or dry?
Lost compression from flooding? Oil the cylinders?
Check for codes?
mattdoc
Mar 14, 2017 12:10 PM
vtechcivic
Apr 21, 2015 07:11 PM
Myredjonda
Apr 14, 2015 07:00 PM
CapYoda
Dec 23, 2001 11:52 AM
TaiChi
Dec 17, 2001 09:09 PM
