Driving on a leaking head gasket - fixing in 4 days
I'm getting my head gasket fixed in 4 days. My local shop wont do a HG job, they will only swap engines. There is a shop that will do it approximatley 150 miles from me.
I've been driving the car in town at low speeds for short trips. Is there any agvantage to changing the oil to try to extend the life incase coolant is getting into the block?
Whachya lookin at?
Rep Power: 288 Re: Driving on a leaking head gasket - fixing in 4 days
Couldn't hurt to clear the coolant out of the oil... it should last 4 days however. Just keep checking your oil. This is just my opinion... I'm not a mechanic by any means.
Head gaskets can fail in different ways so it really depends on how yours has failed. If the failure is allowing combustion gas into the coolant but there is no coolant mixing with the oil, then there is no need to change the oil.
If there is coolant getting in the oil then I would do an oil change with a cheap oil and filter, fix the head gasket as soon as you can, and then do an oil change with your normal products.
Whachya lookin at?
Just check your oil and remove the oil cap and look for white. When my HG failed I had no coolant in the oil whatsoever.
Live for the Twisties
Rep Power: 260 Re: Driving on a leaking head gasket - fixing in 4 days
I'm a delivery driver and my 01 Lx has had a head gasket leak pretty much sicne I got the sucker (not really but feels that way at times).
My best advice with the oil though is to just keep an eye on it like others have said. If it turns an odd color or if it starts to smell unusual or get super black like lawn mower oil then you def want to change it.
I've had success just by watching the oil like a hawk before trips and making sure the coolant is topped off every other day (have to add about a pint or two each fill up). As long you don't have to take long freeway trips and don't race the car around you'll be fine.
I guess my one big secret, although im not sure how effective it actually is, is running the heat all the time. Get's brutal in the summer but hey, i've put 100,000+ miles on leaky gaskets. (that's in TN mind you, *knock on wood* heh)
BREADFAN
04-15-2015 08:58 AM
deus-ex
04-13-2015 12:29 PM
