bit of a knock/tick/some other noise
Old Feb 28, 2008
12345678910's Avatar
12345678910 is an unknown quantity at this point
first off, my car is a 2004 EX coupe. almost 120k km on it, im very good about oil changes every 5000 km....
i think this all started at 20,000 km ago when i hit 100,000 km on my car and started using synthetic oil. i noticed after about the first oil change my car was knocking/ticking on light throttle at about 3k rpm and i had a check engine light come on....
now, once in a while my car cuts out at 4k rpm (like trying to pass someone on the highway). it feels really sluggish, and is starting to concern me. should i quit being a cheap-o and go get my check engine light codes scanned, or is there possibly a way to do this from home?
i know some Chevy's you turn the key from on, to acc, to on a couple times and it starts flashing codes blah blah... anyway to do this on a honda?
any ideas?
Old Feb 29, 2008
Re: bit of a knock/tick/some other noise
anyone?
any sort of direction on where to go with this?
Old Feb 29, 2008
get the code checked, alot of place do it for free. or buy a $30 ebay code reader so you always can check if something happens. im taking a wild guess and thinking its vtec system malfunction (1259).
Old Mar 2, 2008
i might call a couple shops to see if they'll check it..
Good old Canadian Tire will scan the code, and confirm the source of the problem (yay) for $105.. i might do that...
if it happens to be a vtec system malfunction, do you know what i might need to replace..?
Old Mar 3, 2008
emjay's Avatar
emjay is a jewel in the roughemjay is a jewel in the roughemjay is a jewel in the roughemjay is a jewel in the rough
IS Our cars can bus supported? would we need to buy the basing obd2 reader or a canbus obd 2 reader?
Old Mar 3, 2008
usually 1259 means clean out the vtec solenoid oil filter screen and good as new. unless the solenoid doesnt work, then you need a new one. you can open it up tho and press on the lil button to make sure it pops back up.
Old Mar 3, 2008
ronaldo9's Avatar
Make sure you are not low in oil. This code will also be thrown from low oil I guess from not enough oil pressure to go into VTEC. I had this problem from an oil leak I didn't know about from a torn gasket on the cam seal.
Old Mar 3, 2008
where would this be located? the only work ive done on my car is change the oil, so im not too sure where this stuff is. especially, this is my first Honda blah blah....
Thanks..
i think my oil level is pretty good. ill check, and maybe dump some in. good idea, thanks...
vtec92
HIDs and Retrofitting
Jul 16, 2015 03:55 AM
f575gtc
Transmission
Jul 13, 2015 09:16 PM
mistermenphis22
Jul 13, 2015 04:43 PM
06Si_Girl
Jul 12, 2015 12:08 PM
1khilari
Jul 9, 2015 08:12 PM
