Mileage
Old Aug 22, 2006
hockeyc574's Avatar
hockeyc574 is an unknown quantity at this point
Mileage
Hey guys i have an 01' EX and I just hit 80k miles recently and i was just wondering if there is anything i should be worrying about since my mileage is getting high. Its an Auto and I drive it very lightly, barely going over 3500 RPM's when driving. The only problems I have had so far are my alternator going bad and I am getting my Airbag clock spring replaced tomorrow because it has worn out and is the cause of my SRS light being on. I change the oil and filter every 3k miles. SO anything else to worry about?
Old Aug 22, 2006
Syke Fu's Avatar
Syke Fu will become famous soon enough
Timing belt.
Old Aug 22, 2006
civydcex's Avatar
civydcex has a spectacular aura aboutcivydcex has a spectacular aura aboutcivydcex has a spectacular aura about
Valve adjustment, plugs.
Old Aug 22, 2006
hockeyc574's Avatar
what would be the cost of a timing belt, valve adjustment, and spark plugs; also an estimate on labor costs too if possible.
Old Aug 22, 2006
streetglower's Avatar
for a shop to do the timing belt anywhre between $200-$700. honda charges about $500 for a timing belt, water pump and cam and crank seals. at least the one in houston did. Vlave adjustment not to sure. and spark plugs can be done on your own, it is farely simple to do.
Old Aug 23, 2006
civydcex's Avatar
About 650usd. I got all this minus the plugs for 580usd. Figure around 70 for a factory tune up!!!
mgrantaz
General
May 2, 2022 05:40 PM
robjcivic
Mar 12, 2017 12:10 PM
jtcavey
Sep 30, 2015 02:18 PM
hondacivic0253
Sep 29, 2015 08:06 AM
jsmithe2010
Regular Maintenance
Sep 25, 2015 08:15 PM
