Fuel Leak WHERE???
BOOSTED DOHC i-VTEC
Rep Power: 0 Fuel Leak WHERE???
Guys help me out a little. I been smelling fuel/gas in my car for about 2weeks. Took the car to 2 different shop and no problems where found. But they said they smell it too.
Yesterday when I took the car out. I see gas/fuel on ground. Me and my friend spend 4 hours (until 3:30am) trying to find the lead. NO LUKE.
Can someone with a swap outline all the fuel lines.
oh btw the smell is coming from the passenger side by the firewall.
DOHC i-VTEC TiMEX
Rep Power: 338 perhaps a loose hose clamp on the lines?
every couple months, one of the fuel line hose clamps gets loose and starts to leak fuel in my engine bay ... I know because I can smell it.
I just have some generic fuel line from pep boys ... probably not a good idea, but oh well ... it works
Rep Power: 280 under your back seat, to get into the tank there is the fuel pump/filter assembly. There is a screw cap that goes over the assembly. You are probably leaking from the rubber gasket there or fumes are seeping through. Where is the gas spot in the rear or towards the front?
See the black gasket around the top in this pic..?
thats what im talkin about. that should be changed each time you go into the tank. I would check that first.. just pop the seat off, pull the cover off the by removing the 4 screws and check to see if you have fuel puddling in the "moat" like area.
tank cover pic..
thanks to tnaaff for the pics..
tank cover pic..
BOOSTED DOHC i-VTEC
tank cover pic..
tank cover pic..
BOOSTED DOHC i-VTEC
Rep Power: 0 the price of taking to the dealer will be a killer. Esp they charge by hours, it is like $75 per hour I think?.?
If replacing the line doesn't I am going to rip the turbo out and replace all the lines. If that doesn't fix it then.................
Rep Power: 280 hm, did you try pulling the injectors and re-seating them, maybe one is not seated properly? you dont have a return line by any chance? I'm sure you checked most places already.
Rep Power: 304 By the passenger side on the firewall?
Is the connection to the rail for sure.
may be it only happens when in high pressure, hard acceleration.
Test the conection and hoses while some one is reving the car at 4000 rpm at observe the line.
You may have a small hole or crack on the hose.
Just jiggle all hose and pay special attention to conectors and clamps.
Good luck
Good luck
1 Post
Rep Power: 273 what the hell.. the only connections u should have played with doing the swap was the stock metal line already coming from the bacj side of the firewall to the very short line of the hose to the rail.. other than that the only thing i can think of is that the entire FUEL LINE... the metal piping that runs from the firewall to the fuel pump has a crack in it....
here is what u do... before turning the car on... fell around all the cnnectors and hoses to see if you feel anything wet or moist all the way to the back line... if nothing there turn the key all the way to the ON position and wait a minute or 2.. then with the KEY still in the ON position go back and feel all the lines and connectors again.. that should reveal if you are leaking from up top by the fuel rail and connecting lines.... if that fails then...
jack the front (or side) of the car all the way up... make sure the key is on that way it still provided power to the fuel pump.. now crawl under the car on ur back and check the metal lines the go the entire lenght of the car to see if anything if leaking there
BOOSTED DOHC i-VTEC
Rep Power: 0 ^^^ I try that and nothing came out (leave the fuel pump running). I even let the car run and went undernath it.
I havn't try to trace the metal fuel line yet. Maybe I will do that later on. When I have time. If it still leak.
Right now I changed a new fuel line. put 2 clamps on hole the end by the firewall. Headwarp around it, since it is so close to the turbo. It has been good soo far, no leak on the ground or @ the bay. I will take it out on the weekend to see if I smell any gas.
Thx GUYS for ALL these great advice.
Re: Fuel Leak WHERE???
For me it was a leak in the fuel pump filter assembly(under the back seat). Small cracks allowed fuel to leak above the fuel tank. It would usually evaporate before it could reach the ground.
superstanko
04-28-2015 04:38 AM
BREADFAN
04-15-2015 08:58 AM
Lightman
11-10-2001 06:44 PM
