whining noise while driving
Old May 16, 2005
Cyclosporine's Avatar
Cyclosporine is an unknown quantity at this point
hello, lately my tranny has been slipping, and the car vibrates a lot, I went to the dealer and they said there's a piece of the transmision that needs to be change, but I haven't had time to buy the piece and take the car back to the dealer, anyway, I've started to notice now, that my car makes a whining noise (and a very loud one, like the one when you go on reverse), when I go forward and after drving a few miles it goes away, any suggestions ideas of what could it be before I take it to the dealer??
Old Jun 11, 2005
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
did you find out what piece needs to be changed cause i have the same problem.
Injen
Old Jun 11, 2005
Mishkautkin's Avatar
Senior Member
Mishkautkin is an unknown quantity at this point
ball bearings in transmition, i had that.
Old Jun 11, 2005
injencivic's Avatar
^ how do i fix this problem?
i have also been told its my torque converter
Injen
Old Jun 11, 2005
Senior Member
i took it to tranny shop and the parts were like 150 and it was 300 to install - that what was wrong with mine i do not know about yours. do you power shift and rag the hell out of your car? - that could be the problem.
oh you do not have supercharger on your car do you? - cause that might cause a winding noise too :-D
Old Jun 11, 2005
injencivic's Avatar
nope no superchargers lol.... i have never once neutral dropped the car, the only thing possible is i might have waited to long to change the tranny fluid and possibly i might have a slight heavy foot, but thats all... this is the only problem i have had outta my car and its got 98,000 miles on it now. I did have a sensor on my tranny go out along time ago like when i first got it and it was covered under warranty, but i was able to drive at that time and it worked fine until i took it to honda.
Injen
Old Jun 11, 2005
hustlelikem0fo's Avatar
i had a really loud whinning noise on my Maxima beater a while back..... sounded identical to that noise when you go in reverse.
turned out that the bearing on the tension pulley was going back and making that noise.
i got lucky that it was a tension pulley cuz it was a cheap fix..... the alternator pulley or the AC pulley could have had the same bearing problem that that would be a lot more to fix.
but if you're having the same problem i had its most likely the bearing pulley going back.
Old Jun 12, 2005
well...I took my car for the dealer for this problem, they said it was the "base" of the transmision, they changed it, and they gave me the care the next day, I took the car out to run some errands, and 20 min later, my whole transmision cave... and I just went to a rolling stop to my destination, I called the dealer pissed off, so they could send some jerk to pick the car up
so, they decided to actually check the transmision and here's my bill:
1 gasket kit------------------181.14
3 plate, clutch-----------------2.80
3 disk, clutch------------------5.56
6 disk, clutch------------------5.56
9 plate, clutch----------------14.79
1 clutch, one way-------------45.67
1 strainer (atf)----------------48.89
1 Converter, torque----------774.19
1 filter assy-------------------19.25
1 gasket-----------------------1.99
6 Brake Cleaner Wurth----------5.60
1 Fluid (ATF-Z1)---------------5.06
TOTAL--------------------1,348.36
my dealer didn't offer an extended warranty, it was only a 1 year warranty... they totally **** up my car, since I took it to avoid this **** and they didn't, and now I'm f*ck... I'm fighting with those a-wholes to bring the price way down since they admit they f*cked up, and either way I have to wait 8 days to get the parts shipped here and about 3 days for the installation...
so I suggest you all should take your car as soon as possible to your dealer or mechanic or whatever and make them check ALL the transmision and not just the outside, good luck everyone
Old Jun 14, 2005
injencivic's Avatar
damn that sucks.... i was hoping this might be a small fix, who knows it still might be.
Thanks for the info
Injen
Old Jun 29, 2005
apects's Avatar
apects is an unknown quantity at this point
Transmission defect
I had the same problem about 2 years ago. I live in Japan, and the dealer here fixed it for me free of charge, even though it was out of warranty.
Mine is a 2001 1.7 VTEC sedan.
Old Jul 3, 2005
injencivic's Avatar
^ so theres a recall on the tranny?
Injen
Old Jul 5, 2005
I don't know about a recall, but from what I've seen here, it seems to be a 2001 tranny problem, i mentioned this to my dealer, and they talk to their dealer and they only charge me the installation service... it turn out for the best, only payed $600 instead of $2600, and the car feels like a dream now
Xuhme
21
Aug 7, 2023 03:40 PM
moorebl
Aug 29, 2015 08:39 PM
Supramk3
May 11, 2015 07:55 PM
smmahan
Apr 15, 2015 08:17 PM
pazzmore
Dec 24, 2001 07:39 PM
