any other 7thgen out there with these problems????? arggghhhhh
Old Apr 3, 2005
ncirom2003's Avatar
2002 civic 2dr. lx 5spd.
problems:
1)trunk leak that i cant trace and ive tried alot.
2)squeaking from front right of car over bumps and gradients. ( i think its upper strut bushing but car has 18000 miles only)
thers some others but cant remember now
Old Apr 4, 2005
BlackFire's Avatar
BlackFire is an unknown quantity at this point
Well... I had the squeaking noise, took the car to warranty before installing the aftermarket suspension and they had a Service Bulletin for 01 models, I don't know if 02 were included in that SB.
They replaced front control arm busings (both sides), rear bushings (both sides), left strut mount and spring.
Old Apr 4, 2005
ncirom2003's Avatar
thanks. anyone with the leak at all? both civics ive ever owned strrted to leak when i first got it (im assuming b4 i had it also) and i just cant pinpoint the dam leak. no1 i asked could either.
Old Apr 4, 2005
streetglower's Avatar
try getting into your trunk with a light and have someone pour water on the trunk and see where it leaks from.
Old Apr 4, 2005
ncirom2003's Avatar
ill try this weekend maybe. thanks for the idea, its about the only thing i havent tried
Old Apr 4, 2005
CraigW's Avatar
Yes, either pour water or take it to the car wash.
Old Apr 4, 2005
WannaBFast's Avatar
Prowlin' with a Purpose
the trunk leaking is that like above the spare tire well or below? cause if its below, chances are theres a hole where the brackets are...
Old Apr 4, 2005
italy273's Avatar
italy273 is an unknown quantity at this point
i had the trunk leak on my 04. I got a popped my tire on my 17's at night and when i went to get the spare out i found about 1-2 inchs of water where the spare tire is. Went to the dealershp and they replaced all the seals. They said that the seals were not fit correctly when it was at the factory b/c the machine must have messed up. The worst thing was my amp and books got water damaged but Honda of America paid for my amp and books. My amp still works and i could probly sell my books to students.
Old Apr 4, 2005
20civic01's Avatar
20civic01 is an unknown quantity at this point
blackfire, so they replaced all that stuff under warranty? cause i have that suspension noise as well, but i have like 72,000 miles. they probably won't fix it under warranty right?
Old Apr 4, 2005
TSSCivic's Avatar
TSSCivic is an unknown quantity at this point
problems:
My friend with a 2003 EX coupe have that same exact problem. His car have 70,000 miles though. The shocks & the bushing are fine. It turns out that it was his hood that was making the noise. For some reason the hood is slightly loose. It's weird since he bought the car brand new & never got into an accident.
Old Apr 4, 2005
ncirom2003's Avatar
well ill look into the hood thing cus my hood isnt lined up right as of now. im too lazy to just fix it lol. but as for the trunk leak... yea same thing happend to my i went into my trunk to get my detailing stuff and saw a inch or so of water pooled in the bottom. ive been thinking of drilling 1/4" holes in the lowest point of the trunk to drain it. (i figure its easier than resealing the whole entire trunk because i know ill miss some and my car isnt under warranty as far as i know cus i bought it totaled)
Old Apr 4, 2005
CraigW's Avatar
I would NOT drill, there should be drain plugs you can pop out.
Old Apr 4, 2005
ncirom2003's Avatar
oh yeah well i WOULD drill. lol jp but its not like it could cause major problems, although i will look for drain plugs first
Old Apr 4, 2005
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
Check the area around the gascap. That's a common spot for water to get in. They forgot to put sealant around the filler pipe on a lot of civics.
Old Apr 5, 2005
ncirom2003's Avatar
^^^^^^^^ thank you i will do.
CaptainAmerica
Feb 3, 2002 09:36 PM
Diznavis
Jan 25, 2002 11:25 AM
delacampos
Transmission
Jan 2, 2002 02:06 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
Flatlander
Nov 16, 2001 05:38 PM
