Electrical Post information/questions/Issues about Electric parts here.
Honda civic heat problem
Old Sep 18, 2021
Yasir's Avatar
Yasir is an unknown quantity at this point
Hello guys,
Recently i bought 8th generation Honda Civic.
the initial problems that in starting was faced and told by mechanic that car has weak head gasket and it was replaced. The car didnt have temperature valve which was then installed.
currently the problem i am facing is car is not heating up fans turn on at 101 centigrade and turns of at 96.
The problem is when I turn off engine than coolant boiling is heard from engine compartement.
Kindly help
Old Sep 18, 2021
FRSam's Avatar
Click Here
Re: Honda civic heat problem
Are you sure that’s not the AC making noise when you shut the car off? It’ll make a boiling-like sound. If you have boiling coolant, it means it won’t be pressurizing, which would probably indicate a leak somewhere.
Your fans sound like they’re working. Those temperatures seem accurate.
Old Sep 18, 2021
take back to mechanic.
Old Sep 18, 2021
Yasir's Avatar
Thanks for replying.
I understand the sound of AC. But its like from the engine block or something and hosepipe are tight after turning of the engine
Old Sep 18, 2021
Yasir's Avatar
Currently mechanic is travelling somewhere. For him he is like drive it and that happens dont worry. I need to go around 1500 kms in few days and i am afraid if any coolant travelling pipe gets burst out in middle
Old Sep 18, 2021
Yasir's Avatar
Btw how it can be checked if its from AC
Old Sep 18, 2021
measure the temperature with something else and check if the engine is really overheating.
I don't know what you have available there... PK - Pakistan?
Old Sep 18, 2021
Yasir's Avatar
Yes Pakistan.
I have connected computer and it shows temperature within 96 to 101 thats it. Yesterday i tried changing engine cap but didnt work
Old Sep 18, 2021
Yasir's Avatar
Originally Posted by Yasir
Yes Pakistan.
radiator cap*
Old Sep 19, 2021
not from car computer, actual engine temperature.
not sure if you can find laser temp measure equipment there.
If engine is at similar temps, you should be fine.
Chris94
Oct 14, 2016 12:28 PM
Nalmonte
Jun 9, 2015 12:30 PM
04CivicTrouble
May 24, 2010 12:34 PM
crazyconfused5
Jul 18, 2007 01:51 AM
HEBEGEBZ
Feb 6, 2004 02:45 PM
