Electrical Post information/questions/Issues about Electric parts here.
2001 Civic EX alternator bolt broke now the tach is not working
Old 12-12-2010
htulrich's Avatar
htulrich is an unknown quantity at this point
This is for my father in law. The alternator mounting bolt broke we replaced it now when you start the car the tach will work for about 10 seconds during that ten seconds the fuel pump relay behind the glove box is clicking and the battery light is on. After about 10 seconds the relay stops clicking and the tach stops working as well as the temp gauge and the battery light goes out. The engine keeps running but itacts like it has a severe miss about every 2-3 seconds and in turn it has severely diminished power. Also the pcm will not communicate with the scanner (mac mentor I believe). Here is a list of things we have done:
Pulled the pcm and sent it out for repair, sent back they said that it was fine.
Checked alternator checks out ok. 14.1 volts output.
Checked connections to the crank sensor cam sensor and alternator.
Anyone have any suggestions or info on this I have found threads but never any resolution to them. Any help is appreciated Thanks in advance
Hans
Old 12-12-2010
lazlong's Avatar
Re: 2001 Civic EX alternator bolt broke now the tach is not working
Sounds like a bad connection somewhere. check for bad connections or wires anywhere near where you were working. Also check for bad grounds.
Old 12-12-2010
ive seen an improperly grounded alternator fry an ecu before (mounting bolt is the ground). see if you have a spare ecu you can swap in for the same year and model and trans type. if you say it isnt communicating, thats a good indicator it went bad.
Old 12-13-2010
htulrich's Avatar
Ecu was checked they said it was ok I'll recheck the connections and the grounds. What controls the tach? What energizes the fuel pump relay?
Thanks
Hans
Old 12-13-2010
lazlong's Avatar
Originally Posted by htulrich
...What controls the tach? What energizes the fuel pump relay?
The ECM/PCM but, those circuits ground at G101, which is here:
That's the top radiator hose on the right and the airbox in my hand.
Old 12-19-2010
htulrich's Avatar
Been a few days since I've been able to look at it. checked and cleaned the ground (g101) no luck I don't have another pcm laying around but we did send this one off and they returned it and said it was OK. They could be wrong I guess. Maybe I'll try to get a hold of them and see how they tested it any other Ideas.
Thanks
Hans
Old 10-07-2012
Radianceautospa's Avatar
Radianceautospa is an unknown quantity at this point
Has this been resolved . I have the same exact issue
Old 07-01-2015
Dangerousjordan's Avatar
Dangerousjordan is an unknown quantity at this point
Any word on this? I have the same problem as well.
Old 07-20-2015
I checked my alternator and my top bolt was loose and the alternator was just loosly hanging. Replaced the alternator and got a new PCM programmed and all is well.
mattdoc
03-14-2017 12:10 PM
lilbluecivic
11-07-2001 06:49 PM
silverarms
11-06-2001 05:36 PM
liljoe
11-04-2001 01:27 PM
HitlistCivic01
10-27-2001 07:47 PM
Quick Reply: 2001 Civic EX alternator bolt broke now the tach is not working
