Using spray bottle to bleed brakes
"Honda - tried, true & tested...!"
Just curious has anyone used a squirter from a spray bottle for bleeding there brakes.? reason i ask.? i stumbled across this video i think the hose hese using is a little too long lol.
Received 1,126 Likes
Rep Power: 190 Re: Video - DIY Changing front brakes - pads & Rotors
i would just buy the proper tool for $20, i feel like the plastic would get eaten by the fluid.
Re: Using spray bottle to bleed brakes
Harbor Freight hand vacuum pump kit $19.99......
https://www.harborfreight.com/brake-...kit-69328.html
Oh this is USA, not sure if you can find similar in Canada?
I use a Motive setup for my other cars as I am able to adapt that system for the various reservoirs. I am unable to use the Motive system with my 2010 civic so I purchased a Mytivac system . It operates like the Harbor Freight ( iI had no idea they sold that). Some bubbles will come through once you start vacuuming and I was told to use a dab of silicone around the treads and this would stop air from getting in. perhaps I will try that next time
Engineer reply:
Any air pulled past the threads under a vacuum only exits through the bleeder hole and you see it as bubbles in the clear tube that connected to the can and the vacuum pump.
If the little bulge on the bleeder you connected the clear hose to isn't perfect, something like rust corrosion or a poor fit could let air bubbles show up as well.
The air bubbles noticed as a result of those cases----- under a vacuum .........is not entering the caliper or wheel cylinder.
I would not be concerned by that observation. It happens when using a vacuum method.
Mechanic reply: I wouldn't worry about that.
If you take out the bleeder screws to lube em up, yer gonna let fluid leak out and let air leak in the whole time they are out.
You don''t know that whatever you slap on the threads may actually be incompatible, it might actually contaminate the fluid and cause damage to the brake hydraulic system components.
Rubber components in a brake system can quickly swell and soften when contaminated by a petroleum product, whether it's motor oil or KY or Vaseline
At work I might have about 6 different tubes of silicone greases, only one is specifically called for use on assembling a component in direct contact with brake fluid.
I'm not going to see if the other 5 will hurt a brake system.
Phil_Qc
11-15-2004 10:10 PM
XxJDMCivicxX
09-25-2002 05:29 PM
