07 civic driver side front wheel toe in when straight???
Old Jan 15, 2019
Mindtheblind's Avatar
Mindtheblind is an unknown quantity at this point
So I have recently bought a gen 8 civic (154k miles) and it had been side swiped on the front end. So the left front driver wheel was toe in a bit enough to squeeze if driving. I went ahead and ordered and replaced the following. Inner - outer tie rods, control arm and sway link. After the install the wheel was still toe in. Need help on reasons this may be.
thanks
Old Jan 15, 2019
Colin42's Avatar
Re: 07 civic driver side front wheel toe in when straight???
take it to an alignment shop
Old Jan 15, 2019
was planning on doing that this weekend. I did the best self adjustment I was able to do myself. But its I want to say atleast 10%15 Toe in. And I was trying to find other possible causes to that before alignment, that way if alignment didn't work I wouldn't have to fork out more money for another alignment after more parts are replaced.
Old Jan 15, 2019
they can diagnose, you don't need to have them actually do the alignment
regardless, lots of shop offer for you to go back (limited time)
Old Jan 15, 2019
ah yea i guess that's and option. I guess we will see this weekend unless I stumble upon the sudden solution.
Old Jan 15, 2019
if you search for string alignment, that method is much more precise than eyeballing, but not easy either.
Old Jan 15, 2019
yea just need another person for it to be most effective I'm usually by myself so kind screwed on that. Might see if I can drag some one to help me out the car is slammed maybe an few inches off the ground so makes it quite difficult
Old Jan 15, 2019
yeah, the stands for DIY alignment are quite expensive. I only own because I have 4 cars, so saves me in the long run.
some make do with some metal sheet with grease sandwiched. Stands are Flyin'Miata, I own two miatas (lower than the civics)
Old Jan 15, 2019
yea makes sense. The civic is on coilovers so its slammed. I have a 06 NC monster miata ls3 and yea those are low from factory.
DH757
Suspension
Apr 15, 2011 05:12 AM
davidoff1
Mid Atlantic
Feb 12, 2009 07:50 PM
LiKEaFeRiO
Aug 16, 2006 11:52 AM
flipbagz
Detroit
Apr 30, 2005 09:11 PM
streetglower
Jan 27, 2004 07:50 PM
