interior cleaning
Rep Power: 0 interior cleaning
Hey there guys going to be doing a spring cleaning to my interior this weekend. aside from all the dash, and trim plastic to clean, i have some dried white powdery salt stains down on my drivers side foot area on my carpet, soo.. im wondering what would be a suitable prefered product to use without leaving any discolor to the carpet?
Received 1,122 Likes
Rep Power: 190 Re: interior cleaning
"Honda - tried, true & tested...!"
Yes Use Salt Erasure for the Dried Up Salt Stains - spray On Then Brush then Vacuum - Done.!
http://www.canadiantire.ca/en/pdp/sa...-0390421p.html
For the interior upholstery and Plastic trim use ( Tide Cold ) - Mixed with cold water in a Spray bottle. & Spray Your seats & wipe them clean using a Dry microfiber towel. On the other hand If Your seats are really stained bad Looking You will need to use this method Video Found Below. using Compressed Air I have seen really great results from Just spraying my seats down and wiping them Clean. especially on the Plastic Trim Works Excellent You wont beleive how much dirt comes off the plastic trim useing Tide-Cold actually Works Very well and Leaves a great smell behind to.
FYI i cleaned my carpet today and noticed i had a few salt dried stains under the rubber mat i never new i had. anyway the Kicker is i used about 75 /25 Solution of Tide Cold & Water and sprayed & brushed the area and wiped it completly clean i think the way Tide works is it lifts dirt & grease from Just about anything it works great.
Rep Power: 0 Re: interior cleaning
A bit too Late on the Post brags but nevertheless salt erasure worked like a real champ.. on my floor boards, tide does seem to work well on plastics "THANKS - AGAIN
Matrix
Detailing
02-28-2002 11:40 AM
