waxing problem
Old Feb 25, 2002
zackde's Avatar
zackde is an unknown quantity at this point
waxing problem
after waxing the car is shiny but when i looked at it nder the sun the swirl pattern of my rag w/ the wax can be seen.............is it that i put too much wax???or should i use a finer cloth towel??.......i rebuff it but the swirl just change pattern like a HANDPRINT OVER A DEAD BODY that i cant remove!! but it is shiny though!! [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Feb 25, 2002
Mbow's Avatar
I have had this problem with Klasse all in one. I have no idea why that happens. I just switched to megiuars and forgot about it. Maybe someone could shed some insight.
Old Feb 25, 2002
WhiteRiceBoi's Avatar
WhiteRiceBoi is an unknown quantity at this point
yeah alot of people have the misconception fo waxing on adn waxing off in circular pattersns... what i feel best is putting on the wax witha soft balled up terry cloth towel and then takign a really soft fine cloth and removing the wax in one direction in a straight line... this doesnt make a lot of swirls.. swirls most fo all coem from drying ur car with a coarse cloth or not having enough water when washing it... i have a buncha swirls and now I have to get compound and spend about 2 hours buffing my whoel car with a buffer
Old Feb 26, 2002
VNlilMAN's Avatar
The Standard One
i get the same thing with both meguiars 7 show glaze and 26 yellow wax
Old Feb 27, 2002
civicdude's Avatar
If you have the problem that you still see the wax pattern in the paint after pulling the car in the sun...I will tell you the easiest way to remove these marks...It is a trick that many detailers use. What I do, is after i wipe all the wax off the car, I re wash the car with car soap and a wash mitt....then hose the car off and dry it with a chamois. This will remove the wax marks and also any powder that the wax left on the surface.
Old Feb 27, 2002
zackde's Avatar
OOHHH MEN!!!!!
i just washed my car then wax it then now i have to wash it again?????
[IMG]i/expressions/face-icon-small-mad.gif[/IMG]
Old Feb 27, 2002
Mbow's Avatar
<< If you have the problem that you still see the wax pattern in the paint after pulling the car in the sun...I will tell you the easiest way to remove these marks...It is a trick that many detailers use. What I do, is after i wipe all the wax off the car, I re wash the car with car soap and a wash mitt....then hose the car off and dry it with a chamois. This will remove the wax marks and also any powder that the wax left on the surface. >>
Great tip! This also helps to distribute the was evenly.
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
ZSKCivic01
Detailing
Mar 7, 2002 11:11 PM
bignasty
Detailing
Jan 3, 2002 10:35 AM
Civic316
Detailing
Nov 14, 2001 08:31 PM
CiViCPrAnInG2k1
Detailing
Nov 9, 2001 08:34 AM
