Engine Performance Modifications Post your questions about how to modify your engine here Swaps, Flashing, bolt-ons, etc.
engine performance chat
Old Oct 30, 2019
Nelrodjr's Avatar
Nelrodjr is an unknown quantity at this point
Old Oct 30, 2019
Nelrodjr's Avatar
Re: Ktuner and the D17
Working on intake swap, running 880cc injectors. Still working on porting. Opened up exhaust substantially. Still working on thicker plastic intake gaskets and having a custom gring done on the cam, also cleaning and polishing all valves.
Old Oct 30, 2019
Nelrodjr's Avatar
Accepted request, not sure if worked?
Old Oct 30, 2019
Nelrodjr's Avatar
Old Oct 30, 2019
Nelrodjr's Avatar
Still working on the valves and the head. This will take most of my time. Also gonna be running a better turbocharger.
Old Nov 6, 2019
Nelrodjr's Avatar
What kind of oil are you running?
Old Nov 6, 2019
piano55man's Avatar
piano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of light
during the initial startup, i have so much damn mystery oil and assembly lube, i'm going to use walmart sythnetic 5w20 for 20 min.
drain it, change filter, and use 5w20 royal purple.
Old Nov 6, 2019
Nelrodjr's Avatar
Run the Amsoil 20w50, competition diesel. I run that daily no problem. I guarantee it.
Old Nov 6, 2019
Nelrodjr's Avatar
A friend of mine made this out of cheap LS headers for a 1.6 using the 1.6 flange. No leaks gonna run 50lbs of boost. This was because he's bored.
Old Nov 6, 2019
piano55man's Avatar
I'll look into that...
I'm pretty set on Royal Purple or Valvoline with the added zinc crap.
Old Nov 6, 2019
Nelrodjr's Avatar
Something like this would be perfect for your setup. There is a guy in PR that does remote tuning. You can find him on FB Mostro tuning. Check him out.
Old Nov 6, 2019
piano55man's Avatar
he better have sleeves if he plans on boosting over 30psi...
Old Nov 6, 2019
Nelrodjr's Avatar
After he does a dyno run and makes a pass on the track. I will show you what he did. You won't believe me if I told you. We gonna show you. We have several cars out here putting out some power. We just not that big on the social media.
Old Nov 6, 2019
piano55man's Avatar
Where are you out of?
Old Nov 6, 2019
Nelrodjr's Avatar
Fayetteville NC
Old Nov 6, 2019
Nelrodjr's Avatar
But I'm orginally from Massachusetts and my buddies are all from Puerto Rico.
Old Nov 6, 2019
Marcelo Souza's Avatar
Marcelo Souza is an unknown quantity at this point
i works but it’s not the right way to do it the oil is so thick that you run the risk or the oil being to thick to lubricate the rod bearings because the base viscosity of the rated oil is 5 which is thinner vs the 20 which is 4 times thicker, plus you’ll get shitty gas mileage because your pistons will work harder to go up and down because it is moving through a thicker oil and if it’s turbo you will gain a lot of lag
side note, thicker oil does not mean more protection it’s the quality of oil you buy full synthetic has the same amount of protection no matter what rating full synthetic being the best oil
Old Nov 6, 2019
Nelrodjr's Avatar
What engine are you working on?
Old Nov 6, 2019
D17a1@ 10psi
Old Nov 6, 2019
Nelrodjr's Avatar
Been down this road already my friend, the turbo cooks the oil like you would never believe. This 1.7 engine does not have the highest oil psi from the factory. So adding the turbo just adds to a poor oiling system and then we cook it through the turbo. Thats why most people fail on this setup.
Old Nov 6, 2019
I know, I have a oil cooler on my oil feed line I doesn’t do it anymore
Old Nov 6, 2019
Nelrodjr's Avatar
What does your setup look like and what kind of oil are you running? I'm building a block and plan on running the same oil. Have too much time and money invested to risk damaging the block.
Old Nov 6, 2019
I’m just running 5w-20 high mileage full synthetic I would show you a pic but for the setup but it doesn’t ever post when I try to do it
Old Nov 6, 2019
I daily mine so going royal purple it so expensive or else I would, I have royal purple transmission fluid
Old Nov 6, 2019
Nelrodjr's Avatar
What is your oil psi at idle and at high rpm? Are you running A/C and where is you oil cooler mounted and lines run?
Old Nov 6, 2019
Nelrodjr's Avatar
Man it would be cool to see pics of your setup and car, there are so few people that are running the 1.7 boosted without blowing up or being reliable.
Old Nov 6, 2019
Nelrodjr's Avatar
My current build I'm hoping to run 25lbs max boost and 12 to 15lbs daily.
Old Nov 6, 2019
Don’t get me wrong I want to send pics let me try
Old Nov 6, 2019
Old Nov 6, 2019
Oh crap it works
