Ecu swap out issues
Rep Power: 0 Ecu swap out issues
I lost the key to my 2002 Honda Civic. I switched out the ECU and the lock cylinder and everything else that needed to be swapped out around the steering column. The car turns over and the Green Key light doesn't come on but the cluster doesn't read and the code reader is coming up error. What do I need to fix?
Re: Ecu swap out issues
The car turns over
Lots of those mobile lock smith guys can make a s program a key..
You don’t need a ECU to spin the starter motor, sounds like your “replacement” ECU is not powering on at all.
Jdm01Em2
07-29-2006 02:28 PM
