Idle Issues If you have idle issues, post here!
2002 Civic Manual Idling Rough/ Bogging
Old Jan 7, 2024
lwestcomb's Avatar
lwestcomb is an unknown quantity at this point
Car starts fine and after about 5-10 starts running very rough and almost dies but saves itself at the last second. Hitting the gas only makes the engine cut out and doesn’t do anything unless I floor it. It also will bog down while driving. I’ve cleaned the iacv and egr and loosely checked for vacuum leaks. I haven’t been doing much with this car so I don’t remember what all I tried before. PLEASE HELP
Old Jan 7, 2024
FRSam's Avatar
Click Here
Re: 2002 Civic Manual Idling Rough/ Bogging
Sounds like a textbook vacuum leak to me. You make need a smoke machine to check more in-depth.
Old Jan 8, 2024
lwestcomb's Avatar
thank you i’ll look into it.
Old Jan 9, 2024
lwestcomb's Avatar
would you happen to know some common spots. I did some research and the carb or intake manifold is all i could think. Didn’t find any leaks when spraying carb cleaner around
Old Jan 9, 2024
Colin42's Avatar
Does it run better with the iac unplugged?
Old Jan 9, 2024
lwestcomb's Avatar
Last time i tried i don’t think it did but i could try again
Old Jan 9, 2024
FRSam's Avatar
Click Here
The car's more than 20 years old. The lines could just be degrading. Not saying that's what's happening but it's possible. If that's the case, you may need all new vacuum lines.
IACV is more likely though.
Old Jan 11, 2024
lwestcomb's Avatar
were you meaning for a vacuum leak or the valve might be bad
Old Jan 11, 2024
FRSam's Avatar
Click Here
Both are possible. IACV is more likely than completely degraded vacuum lines, but I'm still leaning towards a vacuum leak.
Old Jan 11, 2024
lwestcomb's Avatar
okay I’ll try doing a gasket on it first and if not i’ll replace it and keep you updated. Much appreciated
Old Jan 11, 2024
FRSam's Avatar
Click Here
The way you check function is by unplugging it and seeing if it runs better. Did you follow that up?
Tigerstar
Transmission
Dec 31, 2021 01:03 PM
Nick Bruck
Electrical
Apr 20, 2020 06:45 AM
Schmors
Mar 9, 2015 09:14 PM
THECHRIS
Feb 18, 2010 04:43 PM
