Through your own experience what is best liquid head gasket leak sealer
Just what the title says .if I have a blown head gasket, in order to avoid expensive repairs some people use head gasket leak sealer..used by adding it to the coolant after removing thermostat temporarily. My question is has anyone here used this method and what brand did you use for a successful job.
Re: Through your own experience what is best liquid head gasket leak sealer
Fix it correctly, or don't touch it at all. Head gasket stop leak will do absolutely nothing for combustion gases leaking into the coolant. Like trying to fix a leaking tire with a Band-Aid.
https://www.civicforums.com/forums/3...-problems.html
There are some things I'd maybe contemplate trying to use stop leak for. A failed head gasket absolutely is not one of them.
billz28
Aug 14, 2016 01:02 PM
CBrooks
Mar 15, 2011 02:38 PM
