Overheating or loss of coolant, heater blowing cold If you are having overheating of loss of coolant issues, post here!
Overheating. Cooling fan issues? Idk
Old Aug 19, 2024
Cdvine's Avatar
Cdvine is an unknown quantity at this point
Overheating issues. Radiator fans seem to be running a short cooling cycle. I'm lost. Parts replaced: radiator cap, thermostat, fan switch, coolant temp sensor, fan relays and fuses are good, timing belt and water pump replaced, just had radiator flushed, he checked hoses, radiator for cloggs, thermostat opens. Said when fans do come on his diagnostic tool says ecu showing fans off. I wouldn't bother you if I didn't have to but I'm stumped and so is my bank account. Any help greatly appreciated.
Old Aug 20, 2024
BrotatoChip's Avatar
Super Moderator
Re: Overheating. Cooling fan issues? Idk
Is the reservoir filling up while the radiator is low?
Old Aug 20, 2024
Cdvine's Avatar
It does. Becoming aware of the blown head gasket exhaust getting into coolant. Soon to get after that. At the moment, the quick cycling cooling fans is high concern. Not sure if they're fried but still some how keep functioning? Or if they're ok and the ecu is messed up?
Old Aug 21, 2024
Super Moderator
Air in the cooling system can mess with the fan coolant switch. Fix the head gasket first.
broncobogger
Aug 31, 2014 12:48 PM
pezs2007
Aug 31, 2012 02:11 PM
HondaChick83
Aug 29, 2011 11:32 PM
biederboat
Mar 19, 2011 08:15 PM
specks
Apr 7, 2005 03:59 PM
