Overheating or loss of coolant, heater blowing cold If you are having overheating of loss of coolant issues, post here!
Overheating
Old Apr 16, 2022
UWISHUHADIT's Avatar
UWISHUHADIT is an unknown quantity at this point
Smile Overheating
Originally Posted by gearbox
only the HX has the extra cooler. and yea you need a cooler, no such thing as stock is good enough. 90% of all transmission failure is due to heat, so obviously somethings wrong there. on hot days waiting at long lights, i usually put my car in neutral so it can cool off a bit.
Have issues with overheating and couldn't find out why... bought an after market radiator but also didn't have tyranny lines.. was told to purchase a trans cooler because the radiator is for a manual transmission... hope this solves my issue.. while I was at in decided to replaces all hoses ,however as ture sensors.. head , head gasket, geesh practically the whole car..... what u guys think??
Old Apr 16, 2022
Colin42's Avatar
Re: Overheating
Head gasket is probably shot
Old Apr 16, 2022
Re: Overheating
Yea overheating and blowing hoses. Blew reservoir cap off.. I replaced head and head gasket
Old Apr 16, 2022
Colin42's Avatar
Re: Overheating
Did you do it properly? Did you use an OEM gasket?
Old Apr 16, 2022
Re: Overheating
We bought a full gasket kit
Old Apr 16, 2022
Colin42's Avatar
Re: Overheating
Was it OEM?
Did you get the head checked at a machine shop?
Old Apr 16, 2022
Re: Overheating
use the tests in the videos in the 1st post.
https://www.civicforums.com/forums/3...reference.html
if you can't do the test, have a shop do it.
if it does not pass, the previous gasket/head were not good and need a redo
Old Apr 16, 2022
Re: Overheating
Unfortunately no I didn't take it in. But it was a brand new head
Old Apr 16, 2022
Re: Overheating
again, do the test and get that one checked off the list (or in if it fails)
akronoh77
17
Sep 2, 2014 10:16 PM
flatty
29
Dec 7, 2013 11:05 PM
drmcstford
36
Feb 18, 2013 03:42 PM
pt00323i
Sep 8, 2011 01:56 PM
Phred
May 1, 2011 01:17 AM
