Overheating or loss of coolant, heater blowing cold If you are having overheating of loss of coolant issues, post here!
Is it the block?
Old Jan 23, 2021
user 8230230's Avatar
New Member
user 8230230 is an unknown quantity at this point
Is it the block?
I've been replacing head gaskets and radiators on this 05 Civic for several years now, ever since the first time it overheated due to gasket material from the water pump getting into the coolant and ending up in stuck between the radiator and the rubber cap seal after she let "a shop" do the timing belt / water pump.
The head had always seemed flat enough, I could see light but couldn't get the .002 gauge under the straight edge. Eventually I could see a teeny tiny spot of erosion on the head where the gasket kept failing on the backside of the #2 cylinder. The gaskets used to last about 2 years but the last one lasted only a year, there's no machine shops near us, and the car has near 500k on it so...
8 months ago I put on a reman head + new radiator and for 7 months it was perfect. Now it's overfilling the resevoir again. I really thought I had it this time
I've never pulled the block. There's no visible damage on the tops of the cylinders. I can't even see how it might fail.
FFS Why doesn't someone just invent an automatic cooling system refiller that tops it off everytime the car cools down?
Old Jan 23, 2021
Re: Is it the block?
welll.
if it overheated several times, the block might be a goner after the initial cases... Before the remanufactured head.
Potentially the first head was a goner.
best bet is a "new" engine, service it before you put it in (gasket, bushings, piston rings, TM/WP, seals, etc.)
Old Jan 23, 2021
Colin42's Avatar
Are you using OEM parts?
Old Jan 23, 2021
New Member
I always get the Mahle parts from the local auto parts store.
I'm thinking at this point we've got 3 choices. New car (we can't really afford), long block (that's a lot of money for an 05 with this may miles on it), or tearing the whole thing down, resurfacing the head and decking the block.
The problem with option 3 is She would have to drive the truck to work leaving me no vehicle to haul large auto parts around.
Old Jan 23, 2021
Wankenstein's Avatar
Check the block for flatness the same way you checked the head.
Must use a precision straight edge in conjunction with the feeler gauge.
Blocks generally don't warp but not out of the realm of possibility.
Only use Honda Genuine head gasket.
Old Jan 24, 2021
New Member
The Mahle gaskets are a multi layer coated metal gasket. It looks just like the original afaik but...
I just ordered this Honda Part No.:12251-PLC-004 Gasket, Cylinder Head (Nippon LEAkless). We got to do something to keep it moving and I've done this gasket so many (F#$k&ng) times I've got it down pat.
I've always torqued the head per my manual with my Snap-On digital torque wrench. I'm thinking about going to 75nm this time. Has anyone tried this?
Old Jan 24, 2021
Says in the instruction "don't overtighten" It's not worth the risk of stripping a bolt hole. The head and block expand (heat) at operating temp so if even if it a bolt hole didn't strip at 75nm when the engine is cold it may at operating temp?
Did you check the block for flatness?
Also, there is a wear indicator on the cylinder head that should not be milled past that indicator depth.
Garyd
General 7th Gen
Apr 1, 2018 05:04 PM
mckelj
Apr 4, 2015 02:09 PM
Xer.00
Jun 23, 2013 06:58 PM
Nox
Nov 12, 2012 07:45 PM
