Overheating or loss of coolant, heater blowing cold If you are having overheating of loss of coolant issues, post here!
2004 civic temp goes up after I come off the highway
Old Mar 10, 2020
Subopolois's Avatar
Subopolois is an unknown quantity at this point
This has happened yesterday and then again today.
i was driving on the highway for over an hour, exited and started driving at city speeds (50-60 kmh). When I slow down the temperature gauge shoots up almost as high as it can. I speed up a little more and it starts going back down.
I turned the heat on to full and it only blows cold air until the temperature gauge gets back to normal operation temperature.
Coolant level looked fine, there is no whit smoke/vapor coming from the exhaust, oil isn't milky (I researched a little and came across blown head gasket and checkd the symptoms).
Next I'm guessing there's a block somewhere in the line or the thermostat is stuck? Or what else could it be?
Old Mar 11, 2020
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Re: 2004 civic temp goes up after I come off the highway
Breached head gasket or failed thermostat.
Old Mar 11, 2020
mac25's Avatar
Dr Krieger of Modification
Make sure your fans are turning on.
Wind at speed will cool the radiator. If the fans arnt working it can overheat at lower speeds.
Alif
May 24, 2014 11:06 PM
a242879
General 7th Gen
16
Mar 22, 2014 12:27 PM
amysylvester
Feb 28, 2012 08:15 PM
66 Big Block
Apr 19, 2011 04:04 PM
motayba
Jan 4, 2011 01:07 PM
