OBDII will not link
OBDII will not link
Hello everyone. I’m in need of help. 2003 civic D17A2 5 speed. Original owner. A little back story before we get to the initial prob. Car was tip top until 2010 when trans bearing began chattering. Parked for a couple months while saving $. House was robbed and keys stolen. Car put on back burner for years. Locksmith friend made new keys and tried to program ecu to new key. DLC would not link to his programmer. I started chasing wires. Tried to connect a scan tool with no avail. All fuses good, there is power to the DLC pinout. Everything checked out with volt meter. All dash lights work and everything powers up. Engine will crank but bc of new transponder key the ecu will not send ignition to coils. Fuel pump has power. Everything is working but the OBDII port will not link to any programmers/scan tools. What to do? Thx in advance!
Super Moderator
Received 1,836 Likes
Rep Power: 195 Re: OBDII will not link
Usually when we see scan tools that will not connect to the PCM it has been fried due to loose alternator bolts.
Pretty sure I would never attempt to start a car with 9yr old gas in the tank.
But if you have changed out that gas, then pulling the fuel pump relay and bypass with jumper wire should allow it to start if there are no other issues.
I agree though, sounds like your PCM is not working.
Thx I’ll check the alternator bolts this eve.
i have drained the old gas out and replaced with fresh gas. Also changed oil. I did this by bypassing the relay and jumping the fuel pump straight to the battery. Refilled the tank with 2 gal of fresh gas then drained it again clearing the lines and replaced again with fresh gas. I’ll see if I can find an ecu from the local salvage yard. Not sure why it would be fried bc everything was operational when parked. Nothing touched until now. Just simply needed a new key made and Transponder programmed to the ecu, but hey, anything is possible I suppose.
Thank you all for your responses. I’m just stumped at this point
Just a respected update for those who reached out. After multiple failed attempts to connect to the OBDII port I removed the ground from the alternator and scuffed the surface as well as manhandling the OBDII port connector and was able to get the pcm to link. EVERY TIME! Called my auto locksmith buddy and he was successfully able to program the pcm to the new key. Started up and runs like a champ. Now to fix the initial prob that began in 2010. Thx to all who chimed in on this thread. I really appreciate you taking your time out to try and help. I was beating my head against the wall on this one.
Matt2789
05-07-2011 06:46 PM
lynz
09-25-2010 01:20 AM
bellabri287
12-06-2006 12:32 PM
