Bad ECU 2002 Honda Civic
Rep Power: 0 Bad ECU 2002 Honda Civic
When my car hits 60MPH and ive been driving a while my ECU starts sparking, not even a joke, that thang is about to burst to flames man! I'm in a tight money situation, and i cant take her to the shop so id rather do it on my own, just came looking for info where I can get a new ECU, that is NOT a grand. Also if anyone can direct me to any DIYs so that i can install it myself, or if there is anyway to repair/reset the ECU. Any information would be great. Im not too familiar with the computer, I appreciate all info in advance.
If needed; I live around Tampa FLA area, and the vehicle is 2002 Civic LX, automatic. Sorry if i was vague, any other questions, let me know. Thanks!
Rep Power: 0 Re: Bad ECU 2002 Honda Civic
I'm amazed at the story and would like to see this. Got video?
Have belts or a timing belt service been done recently or the alternator replaced?
Are the alternator mounting bolts tight?
If you just want to toss a PCM at it, be aware that it needs to be programmed for the immobilizer keys before the engine can run.
The only semi-easy way around that that I know of is to get the matching ignition/steering column lock with the keys that match the PCM.
Im not too familiar with the ECU, PCM, or TCM. I constantly have a Camshaft sensor issue, just about every month. So i figured i just had a bad ground and after i finished that project, nothing changed. I noticed my ECU sparking after driving for about an hour and then my car LOCKED UP. Steering locked, brakes locked, gas pedal, then my whole cluster lit up. Also, my transmission is shifting early and a tad erratic, i then figured that it was my trans solenoids or TCM. But after seeing the ECU sparking i jumped to thinking my ECU is about to go out on me. Ive never experienced a lock up like that. And i have no clue what the hell is going on with her. Thanks in advance!
Update. Just went for a drive, going about 60, al gauges dropped to zero and fire started spitting from under my hood. Couldnt catch it on vid happened too soon.
Update: Was just driving. All gauges dropped to zero, ebrake, CEL, maintreqd light, oil and battery light came on, EVERYTHING LOCKED gas, brakes, steering. Then all i see and hear, is my ecu sparking. WTH IS GOING ON?!
FYI the brakes and steering cannot 'lock up', you still have control over the car but it requires a lot more effort to do so, as you coast to a stop you can guide it to the side of the road.
Don't care about sparks or fire yet, I want to know exactly what you are looking at first.
Received 1,441 Likes
Rep Power: 338 Re: Bad ECU 2002 Honda Civic
the ECU is not in a visible place, in other words.
Strycker
21
10-20-2015 10:19 AM
Pfatfinger
10-07-2015 12:39 AM
MamaBear2015
09-27-2015 06:31 PM
toastyghosty
32
12-26-2001 02:03 AM
