Head is off, Where is the failure? PICS
Old May 2, 2019
Bosco19's Avatar
Bosco19 is an unknown quantity at this point
Hi folks,
I think I see the failure but you all have seen tons more of these than I have. It seems like a much cleaner area on #1 exhaust side with a matching cleaner spot on the head. Engine failed pressure test on #1 pushing the radiator level up when pressure was applied at TDC.
Old May 2, 2019
mac25's Avatar
Dr Krieger of Modification
Re: Head is off, Where is the failure? PICS
You probably already know but check to make sure both the block and head are level. Usually a warped head causes the failure/results from failure.
New head gasket wont do sh$$ if the head is not true.
Old May 4, 2019
Slumpertcivic's Avatar
You can clearly see the baked on head gasket coating extending from combustion area towards the water jacket holes on #1.
in your case I suspect the leak was happening inbetween the layers of the head gasket.
Afer getting that much antifreeze everywhere, take great care to clean all electrical plug with contact cleaner.
Old May 4, 2019
Bosco19's Avatar
Yup. After cleaning up the head here is the problem area.
I got electraclean on the list. Thanks!
Old May 7, 2019
Bosco19's Avatar
Found a decent machinist not too far away. It's a treat to watch a pro at work. He said it's never been surfaced. Stock Honda steel plate gasket on the car. You think it's the original at 220,000 miles ? Hope the next one lasts that long.
Roadglide04
Jan 16, 2019 05:46 AM
matthew_burnett
Apr 14, 2012 03:01 PM
lovinthevtec
Jun 21, 2008 06:37 AM
lovinthevtec
Apr 27, 2008 04:14 PM
gearbox
Bolt-on Engine Performance
309
May 30, 2004 01:21 PM
