P1457 or P1456 code
Old Jun 8, 2010
nmastereal's Avatar
nmastereal is an unknown quantity at this point
P1457 or P1456 code
Ive seen in the thread the meaning of these codes. Here is the situation,
i went to autozone to get it scanned, they said it was P1457 i believe. they said first fix would be to change the gas cap. So i put a honda odyssey gas cap on. Had a cousin a visited far away reset it via his works obd tool. It was cleared then about a week later, didnt open the gas cap since. it comes back on again.
I could use all the help i can get because i dont have the money to dish out to dealer.
Civic 03 Sedan LX
Old Jun 8, 2010
DannyK35's Avatar
I'm bigger than you.
DannyK35 is a name known to allDannyK35 is a name known to allDannyK35 is a name known to allDannyK35 is a name known to allDannyK35 is a name known to allDannyK35 is a name known to allDannyK35 is a name known to allDannyK35 is a name known to all
Re: P1457 or P1456 code
Again, those two codes are (on the site!):
P1456 EVAP Emission Control System Leak Detected (Fuel Tank System)
P1457 EVAP Emission Control System Leak Detected (Control Canister System)
If you put on a new gas cap, did you make sure that you clicked it enough times when you tightened it? Other than that, I am sure that the members will chime in to help you out.
Old Jun 9, 2010
nmastereal's Avatar
yes i saw them in that thread, and yes i did check the gas cap again (made sure it clicked)
any help would be much appreciated
Old Dec 5, 2020
douglassharris's Avatar
douglassharris is an unknown quantity at this point
I know this thread is VERY old but in case it helps anyone who is reading it:
I had a 1457 code and fixed it by spraying the solenoid valve area next to the gas canister under the car with sealant. I hope that fix lasts a while. I recently got a 1456 code but the alternator was dying at the time and the whole car had low voltage so I'm hoping the 1456 code was a side effect of the low voltage caused by the valve not being energized enough to close. I'll find out after the alternator is replaced by the mechanic.
mrohitredd
Jan 23, 2015 11:10 PM
Anticrime
Dec 2, 2011 09:46 AM
GreenMachineDX
Mar 24, 2010 04:57 PM
fuledya
Oct 27, 2006 03:39 AM
