Should I run full synthetic in new Civic?
I am thinking of just running a good full synthetic of the same 0W20 Honda suggests in my new Civic. My thinking is synthetic will better protect my new engine’s internals, and extend its life possibly even further. I change every. 3k with conventional oil, so I figure a full synthetic would be every 4 to 5 thousand max? A dealer salesman told me Honda suggests a synthetic blend in new Civics, is that true? Seems to me it a full synthetic would outperform a blend.
Re: Should I run full synthetic in new Civic?
I change my oil with 0w-20 Pennzoil Platinum full synth, usually when my oil life meter reaches around 15%
Run from..? Whatcha mean?
I ran the first factory oil in my car until it reached 5%, and I've been running Pennzoil Platinum 0W-20 ever since. AutoZone always has 5qt Pennzoil Plat with a mobil-1 filter deal for $35. I buy 5 quarts, use 3.7, and keep the unused quart in a cabinet. Filter done every other change, so me and roomie bank those extra filters. All hondas (exc s2k) use the same filters, and I have other friends that have me do oil changes for them, so I have that going for me too
Honda makes a very good synthetic blend (I have a UOA on it) but can’t go wrong with a full synthetic. I ran my Fit up to 10k miles with semi synthetic.
Get the oil tested if you want to know it’s true life expectancy. I use Blackstone labs.
The original oil is the best oil to run on a new engine , it helps the engine to bed in. Changing the original oil too early and adding really good quality oil will actually have the effect of forcing the engine to run itself in for a longer period before you are able to subject it to full running loads. . As regards the "worry" meter it is safe to regard it as having at least a 5% margin of error just like the speedo. Changing oil at 15% is a waste of your time and money.
Just stay way from them junk Fram (orange) filters. I usually use Wix.
I'm rocking a purolator boss filter at the moment. I'm not new to the oil change game. lol
justinleblanc
16
Dec 27, 2010 03:16 PM
liubhs02
Aug 16, 2006 07:10 AM
zen_master
Jun 12, 2005 12:43 AM
civic02ex
19
Mar 29, 2003 01:59 AM
