Electronics Post your questions about Electronics problems here!
? what do these warnings mean
Old Aug 8, 2020
oldbeek's Avatar
oldbeek is an unknown quantity at this point
Warnings on dash board Check power steering, check abs and check VSA. This just started on a low milage 2016 civic. Is there anything in common to look for? Car is not here to pull codes yet. Never heard of a VSA??
Old Aug 8, 2020
Colin42's Avatar
Re: ? what do these warnings mean
Check the battery and battery connections
Old Aug 8, 2020
VSA is vehicle stability assist. Honestly, if you're getting a christmas tree light show, like Colin said, check your battery connections and also any ground connections. Highly unlikely that there's an actual problem with all that at the same time
Make sure battery connections are tight and drive around for a bit. If you feel so inclined, disconnect negative terminal for a good 30 seconds, reattach, make sure connection snug, then drive around.
Yanks12025
Aug 16, 2017 06:27 PM
Steve Lane
May 18, 2016 08:57 PM
Kryptoniteking
Oct 2, 2008 03:23 AM
n00dleboy
Dec 11, 2002 09:23 AM
hose2k1
Mar 13, 2002 10:49 AM
