angel eyes fogging due to t.o. weather?
Old Nov 26, 2003
8701's Avatar
8701 is an unknown quantity at this point
hey ive had my projectors for almost a month now and havent had ne problems with them fogging up....until now due to the cold temperature. is this because of the cold weather or a bad seal?
Old Nov 26, 2003
SedanBoy's Avatar
SedanBoy is an unknown quantity at this point
u probably need to reseal them. and make sure the sockets fits properly for the bulbs. u might be leaking there.
good luck
Old Nov 26, 2003
Bluelle's Avatar
Bluelle is an unknown quantity at this point
yeah its the weather man.....ive had mine for more than a year...its goes aways once it gets warmer......ull have that most of the winter..get use to it
Old Nov 26, 2003
Blkcivic's Avatar
sealin it won't help much, cuz u get them neways.....
Old Nov 27, 2003
FurBall's Avatar
FurBall is an unknown quantity at this point
Well, you definately have a bad seal.... Most likely the bastards that make your headlights didn't think about Canadian weather... Probably there's shrinkage, and/or they just didn't do it right.
My stock headlights get fogged up BAD when I use either a pressure washer, or go through a car wash
I had Telly open them up to black them out, that's why I resealed them 3 times already, and this third time, I put on 3 coats of silicone, and I just found out the driver side fogged up AGAIN.... it kinda dried out on it's own in the past few days fortunately, but I'm still screwed... I'll have to crack em open again, and I'm basically banned from carwashes for the entire winter!
Old Nov 27, 2003
TeLLy's Avatar
Yes, it's an Acura EL
Fuzzy, why won't your headlights just stay SHUT dammit! Makes me feel all crappy.
Old Nov 27, 2003
nitehawk's Avatar
My Projectors always fog up too, even after being re-sealed. I take them out for the Winter and use my stock blacked out headlights instead. They fog up a little too once in a while but it goes away overnight.
Old Nov 27, 2003
8701's Avatar
yea it sucks...they only fog up after i have the low beam head lights on for a lil while..is this cause of the bulb maybe??? or is cause on the back of the headlights it seems that there are little drain holes...should i seal that up to or leave them open???
cause i can drive for a while in the day and the lights are fine ...im using polarg h1s btw...ne suggestions for a better bulb?
and i know how to aim the headlights...except for the low beam bulb i cant get to the screw which makes it go up and down on the passenger side...ne ideas how to get to the screw?? cause goin through the fender doesnt really help
thanks for all the help..really appreciate it
Old Nov 27, 2003
Blkcivic's Avatar
the bulbs deson't effect it... my lights fog up now only at night time when my lights are on, its because the air inside the housin is cold and when u turn on the lights.... it creates heat and condensation occurs. I think the material of the headlights is just cheap compared to the oem ones. Sealin it again helps but the lights gets fog up once in a while
Old Nov 28, 2003
lounge_8180's Avatar
lounge_8180 is an unknown quantity at this point
i don't have projectors but cleared oem ones. my headlights started to fog up too, but just the left side. it started to fog up last week when it was very cold and raining. im worried that it''ll get worse when winter comes. what should i do ????
Old Dec 14, 2003
BIG's Avatar
BIG
for the angel eye projectors you ahve to make a custom housing for the penut bulb.....since the fitting is different then our stock one
GolNat
Nov 27, 2018 03:32 PM
JetsterDajet
52
May 8, 2016 12:11 AM
ChrisHandHonda
26
Sep 25, 2015 11:28 PM
Shadowbandit
Wheels and Tires
Sep 16, 2015 09:34 PM
Jrosa
Sep 14, 2015 08:24 PM
