Engine oil flow rate?
Hello everyone, I am working on installing a 30 plate heat exchanger to help warm my oil quicker and to help keep it cool in the summer. The heat exchanger I bought isn't too restrictive, I can easily blow through it. However, I am wondering if adding a heat exchanger and a few feet of 10AN hose (5/8 inch) will restrict the oil flow significantly. I am quite sure that the bearings would still be the main restriction and the restriction of the heat exchanger and hoses would be negligible, but just checking.
I looked up the flow rate of the oil pump and I found that it can flow 10+ gallons of oil per minute at higher RPMs, which really surprised me. I can't imagine that there is actually that much oil flowing through the engine though, so I'm thinking that rating is probably for just the pump when it isn't working against any restriction and that the actual flow rate is much less than that when the pump is working against the restriction of the bearings, passages, filter, etc.
So does anyone have any idea roughly how much oil actually flows through the engine at higher RPMs? Thank you a lot in advance, I have looked all over for this info and I can't find anything, so any help would be greatly appreciated.
Re: Engine oil flow rate?
I had no way to know if for some reason he thought my setup might be too restrictive and starve the engine of oil or something. I have no way of knowing what someone else is thinking. I was asking a serious question and expecting serious responses.
Yes, I wrote that facetiously.
D17, on one hand I admire how you don't hesitate to try different things on your car. However, on the other hand you seem to have a history of posts that ask questions for thoughts or help when some of the things you tried didn't work out so well. Some times less is more (better).
You are the same D17 who's car was vandalled by one your neighbors in the apartment complex you live, aren't you?
If not I apologize.
If not I apologize.
If not I apologize.
If not I apologize.
However, out of all of the modifications I have done, I have been satisfied with most of them. I would much rather daily drive my car as it is right now than a stock 7th gen. I have experienced this car stock and I have experienced it the way it is now set up, and I personally prefer this. No it's not perfect, but IN MY OPINION it's much better for the way I drive it than it was stock. Not everyone will agree with me on that and that's fine, we all have our own preferences and priorities.
Also, I don't modify things just for the sake of it, I only modify things when I believe that there is an actual benefit to be had. This is why I installed an oil temp gauge before I decided that I needed to modify anything oil related. There is no point in wasting time and money trying to solve a problem that never existed. However, from the temp readings that I am seeing along with the condensation problems I have had, I decided that my engine could benefit from an oil to coolant heat exchanger, which is why I am installing one.
And yes, I did have a problem with a neighbor vandalizing my car several times at an apartment complex I used to live at.
Instead of upgrading the engine to make more power, I have been focusing more on upgrading the car itself (adding gauges, EPS, brakes, suspension, etc) since I am planning to K swap in the future. Also, the few parts I have recently purchased for my engine (such as this oil to coolant heat exchanger setup) are parts that I can easily swap over to the new engine. A full list of the mods I have done can be seen in my profile.
The other upgrades besides the engine is probably money well spent. However, when it comes to bolts on for a D17 all-motor for power....you simply cannot polish that particular turd that way. Other than fuel effeciency it doesn't seem like a good strategy to get the most out of engine that was design to get granny to the store or a daughter off to college.
My neighbor has an 03 Civic auto and was curious how mine drove with the upgrades I did, so I let him drive it to see what he thought and he said it feels a lot more powerful than his car. I then drove his and it does feel noticeably slower and less responsive than mine, the brakes didn't feel as strong, and it didn't feel nearly as confidence inspiring as mine does around corners. However, his car feels a lot more refined than mine does. It is a lot quieter and has a smoother ride because the exhaust and suspension is stock and doesn't have the vibrations that mine does from having stiff motor mounts, and refinement was no doubt one of Honda's priorities when they designed these cars. So for what it was designed to be it is a great car, but my personal preference is a more sporty feel, refinement isn't nearly as important to me as performance.
Where would you guys put the oil temp sensor with a setup like this? Would you put it in the flow of oil going from the engine to the cooler or in the flow of oil coming out of the cooler and going to the engine? I'm thinking it would be best to be measuring the temp of the oil coming out of the cooler since that's the temp of the oil that is on its way to the engine's bearings and other moving parts and therefore the temp that is most important. Thanks
Ideally before cooler and after cooler would be nice. After cooler temp would let you know that the cooler is working and before cooler would let you know how hot the engine is making the oil.
Also, is it okay to start pushing it hard as soon as the oil coming out of the cooler/warmer reaches normal temp? I'm sure the oil in the pan would still be a bit cool at that point, but it should still be okay to push it as long as the engine is receiving warm oil, right? Thanks
http://www.tuneruniversity.com/blog/...l-temperature/
any engine works that way.
there's a reason street cars do not have a oil heater system other than the combustion itself.
there's a reason you can't find the oil flow in the internet also - it doesn't matter that much unless you are designing an engine.
overkill
overkill
Also, I have noticed vanilla pudding under my oil cap when driving in cold weather because the oil often doesn't heat up enough to evaporate condensation out of it. That's bad, water is a poor lubricant and causes rust.
Apparently engineers don't think it's overkill since a lot of cars come with oil to coolant heat exchangers from the factory.
why do you keep asking things that are surely not fit to be in a common internet forum?
Things that surely does not matter much if any at all?
Go apply for Honda if you so much wants to know. Leave us alone
streetglower
18
Jul 4, 2012 12:58 AM
QBoi
Apr 17, 2005 11:32 PM
