WTF is this engine? - Honda Civic Forum
LinkBack Thread Tools Search this Thread
Old 1 Week Ago   #1
D17VTECPOWER's Avatar
D17VTECPOWER is just really niceD17VTECPOWER is just really niceD17VTECPOWER is just really niceD17VTECPOWER is just really nice
WTF is this engine?
I am so confused. This engine looks just like a D17, but it's apparently a D15B? WTF is this? Is it just a D17A with a different name or something? Maybe it was mislabeled?
https://www.ebay.com/itm/2001-2002-2003-2004-2005-Honda-Civic-1-5L-SOHC-Vtec-Engine-JDM-D15B-EX-LX-DX/263732189944?hash=item3d67a9daf8%3Ag%3ASnsAAOSwdPp bErxH&_sacat=0&_nkw=jdm+d15b&_from=R40&rt=nc&_trks id=p2380057.m570.l1312.R2.TR0.TRC0.A0.H0.TRS5
D17VTECPOWER is offline   Reply With Quote
Old 1 Week Ago   #2
Allow me to explain through interpretive dance
Re: WTF is this engine?
Is something wrong?
Something you don't understand?
Is google (LINKYCLICK) not turned on in your area?
ezone is offline   Reply With Quote
Old 1 Week Ago   #3
pleasure spiked with pain
GolNat's Avatar
GolNat is a splendid one to beholdGolNat is a splendid one to beholdGolNat is a splendid one to beholdGolNat is a splendid one to beholdGolNat is a splendid one to beholdGolNat is a splendid one to beholdGolNat is a splendid one to beholdGolNat is a splendid one to beholdGolNat is a splendid one to beholdGolNat is a splendid one to behold
LOL, he didn't have a coupon.
GolNat is offline   Reply With Quote
Old 1 Week Ago   #4
Honda made more than 3 different engines.
Honda makes more engines than any other company in the world
Old 1 Week Ago   #5
Quote:
Originally Posted by ezone View Post
Is something wrong?
I did Google it. I was only finding D15B engines like this. When they are called the same thing but are clearly different, how do I know which one they are talking about?
Old 1 Week Ago   #6
Super Moderator
sdaidoji is offline   Reply With Quote
Old 6 Days Ago   #7
Quote:
Originally Posted by sdaidoji View Post
What you don't understand is that there are several engines called the D15B, so I have no idea which one this is.
Old 6 Days Ago   #8
C&P from wiki:
D15B VTEC
  • Found in:
    • 1992–1995 Honda Civic Vti (Japanese Market)
    • 1992–1998 Honda CRX DelSol (Japanese Market)
      • Bore and Stroke: 75.0 84.5 mm
      • Displacement: 1,493 cc (91.1 cu in)
      • Rod Length: 137 mm
      • Rod/Stroke: 1.63
      • Compression: 9.3:1
      • Power: 130 PS (96 kW; 128 hp) at 6800 rpm[7]
      • Torque: 14.1 kg⋅m (138 N⋅m) at 5200 rpm[7]
      • VTEC Switchover : 4,600 rpm
      • Redline: 7200 rpm
      • Rev-limiter: 7200 rpm
      • Valvetrain: SOHC VTEC (4 valves per cylinder)
      • Fuel Control: OBD-1
      • Head Code: P08
      • ECU Code: P08 (small case ECU)***
D15B with 3-Stage VTEC
Main article: 3-stage VTEC
This section does not cite any sources. Please help improve this section by adding citations to reliable sources. Unsourced material may be challenged and removed. (July 2013) (Learn how and when to remove this template message)
3-Stage VTEC is a version that employs three different cam profiles to control intake valve timing and lift. Due to this version of VTEC being designed around a SOHC valve head, space was limited; so VTEC can modify only the opening and closing of the intake valves. The low-end fuel economy improvements of VTEC-E and the performance of conventional VTEC are combined in this application. From idle to 2500-3000 RPM, depending on load conditions, one intake valve fully opens while the other opens just slightly, enough to prevent pooling of fuel behind the valve, also called 12-valve mode. This 12 Valve mode results in swirl of the intake charge which increases combustion efficiency, resulting in improved low end torque and better fuel economy. At 3000-5400 RPM, depending on load, one of the VTEC solenoids engages, which causes the second valve to lock onto the first valve's camshaft lobe. Also called 16-valve mode, this method resembles a normal engine operating mode and improves the mid-range power curve. At 5500-7000 RPM, the second VTEC solenoid engages (both solenoids now engaged) so that both intake valves are using a middle, third camshaft lobe. The third lobe is tuned for high-performance and provides peak power at the top end of the RPM range.
  • Found in:
    • 1995–1998 Honda Civic Ferio Vi (EK3, Japanese market)
    • 1998-2000 Honda Civic Vi-RS
      • Bore and Stroke :75,084,5 mm
      • Displacement : 1,493 cc (91.1 cu in)
      • Rod Length : 137 mm
      • Rod/Stroke : 1.62
      • Compression : 9.3:1
      • Power : 130 PS (96 kW; 128 hp) at 7000 rpm[8]
      • Torque: 139 Nm at 5300 rpm
      • Redline : 7200 rpm
      • Valvetrain : SOHC, four valves per cylinder
      • Connecting rod length : 137 mm
      • Connecting rod big end diameter : 48 mm
      • Fuel Control : OBD2b
      • Head Code : P2J-07
      • ECU Code: P2J (small case ECU)*** AUTO CVT: P2J-J63*** MT P2J-003*** & ***MT P2J-J11***
      • Piston code : P2J
Old 6 Days Ago   #9
C&P from wiki:
D15B VTEC
  • Found in:
    • 19921995 Honda Civic Vti (Japanese Market)
    • 19921998 Honda CRX DelSol (Japanese Market)
      • Rod/Stroke: 1.63
      • Redline: 7200 rpm
      • Head Code: P08
  • Found in:
    • 19951998 Honda Civic Ferio Vi (EK3, Japanese market)
      • Rod/Stroke : 1.62
      • Piston code : P2J
I don't know which engine that is. I looked up pictures of both, but neither one look like the engine in question.
Old 6 Days Ago   #10
Could be a random engine pic. Looks like an old Accord engine? Could be anyf'nthing.
If you cannot read the engine code stamped on the block, you can only guess.
Old 6 Days Ago   #11
I can read the code. It's a D15B that looks exactly like a D17A. Maybe it was mislabeled?
Old 6 Days Ago   #12
Oh, I was looking at the one with the black valve cover.
D15x looks like your D17x because it's of the same engine family and probably even similar years, just smaller displacement version that was used in other world markets. That engine was never used in the USA.
Old 6 Days Ago   #13
I see. That makes sense. Thanks. Any idea where I could find specs for it?
Old 6 Days Ago   #14
Japan
Old 6 Days Ago   #15
Japan
Any idea what kind of car it's for?
Old 6 Days Ago   #16
Quote:
A Japanese car? Some other country?
You would really need to get the actual code stamped on that particular block, so we all might get to find out what it is.
All you have is a blurry ebay picture and a seller writing up whatever he wants you to read.
FWIW it doesn't really even have to be for a car at all. Could be an industrial engine for all we know.
Thread Thread Starter Honda Civic Forum Replies Last Post
WTF?! B20c?! WTF?! Running Riot General Honda Civic Forum Archive. 4 05-07-2010 02:22 AM
WTF IS GOING ON!!!HELP (engine) CivicHatch9one Mechanical Problems/Vehicle Issues and Fix-it Forum 24 09-27-2005 05:07 AM
WTF!!!! VTEC cobra "very tall engine cooling" 02boostlessCIV General Automotive Discussion 28 12-20-2004 08:07 PM
WTF??? check out this 95 civic..."votec engine" keffin General Automotive Discussion 7 11-07-2002 05:17 PM
this engine grinding has got me worried.........wtf........... civicbluestreak Mechanical Problems/Vehicle Issues and Fix-it Forum 1 05-15-2002 04:16 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
© 2018 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
