View Poll Results: Will polishing the inside of an intake manifold improve performance?
Yes, it will improve performance
0%
No, it won’t do anything at all
100.00%
No, it will reduce performance
0%
Voters: 3. You may not vote on this poll
D17VTECPOWER threads consolidated - how a member should not behave
#1891
Prelude Owner
Re: Will an alternator fry if it’s overloaded?
I have never bought one but where does it say this?
If it can't charge a battery/run a load then what good is it? Alternators are designed to do this.
You have:
A.) Something wrong with your car that is causing these issues.
B.) Poorly made alternators off eBay that can only handle minimal loads
C.) A combo of both A and B
D.) Bad luck
Poor installation like loose bolts or wires can cause premature failure also.
You have:
D.) Bad luck
#1892
Received 1,440 Likes
#1893
You have:
D.) Bad luck
You have:
D.) Bad luck
#1894
Very satisfied with this alternator. The voltage even stays above 14 volts with the electrical system fully loaded at idle. I can't make the voltage go below 14 volts no matter what I do unless the PCM puts it into low charge mode when it's not under much load. The stock alternators couldn't even keep the battery from draining when fully loaded at idle, so this alternator is a HUGE improvement! I like it a lot!
#1896
Do any LED headlights not suck?
I have not been satisfied with any of the LED headlights that I have bought. The first kit worked well for about 4 months, then one of the headlights got very dim and died. The brand of that kit was Iegeek, and the kit was about $30. I figured "Oh well. That's what happens when you buy cheap Chinese crap." The second kit I bought was made by Cougar Motors, and it cost a little over $40. That kit worked well initially, but after about 6 months, both headlights got yellow, and eventually one died completely. I wasn't happy, so I bought a Hikari LED headlight kit for over $70. Hikari is apparently a well respected Japanese brand, and it had a lot of great reviews. Initially, the performance was a little better than the cheaper ones, but nothing significant. However, if they lasted at least 2 or 3 years, it would have been worth the price to me. Too bad they didn't. After about 1 year, 1 of the headlights is getting very dim and turning blue. Now I'm pissed off because I wasted over $70 on more junk. However, these headlights have a 2 year warranty, so I may be able to get them swapped out. But my question is are any of the LED headlight kits decent, or do they all suck?
#1897
Rep Power: 338 Re: Do any LED headlights not suck?
#1898
Anyone else had a wheel fall off?
I was driving through a neighborhood at probably 10 MPH maximum and all of a sudden, the back of my car dropped. I looked out the mirror, and I saw that the wheel was missing! Luckily, a very nice mobile mechanic stopped and gave me lug nuts and let me use his tools to put the wheel back on. I have American Racing rims with the correct lug nuts, and I always torque them to spec whenever I remove a wheel. I called the police to make a report, and the police officer said "Sir, wheels sometimes just rattle loose. No one is trying to hurt you." Just curious if any of you ever had a wheel fall off while you were driving.
#1899
Prelude Owner
Re: Anyone else had a wheel fall off?
Judging from your past experiences someone probably loosened your lug nuts. A properly torqued wheel with the correct lugs doesn’t just fall off.
Move your residence!!!
#1902
Received 1,126 Likes
Rep Power: 190 Re: Anyone else had a wheel fall off?
Hide them better.
Can also get wheel lock nuts, it will make it slightly harder for someone to mess with it, but more importantly it will be more obvious if someone tampers with it
#1904
Rep Power: 78 Re: Anyone else had a wheel fall off?
i had a highschool girlfriends father loosen mine. as i was taught in drivers ed, i always walk around the car before driving though to make sure the tires are not flat and there is nothing behind the car. i actually noticed a small gap behind a lugnut and touched it, it was loose, they were all loose. caught it before driving!
#1905
#1906
Edit by moderators:
street racing is not condoned by the forums, so this post was edited
#1907
At this point, it's YOUR FAULT for not fixing the problem.
That problem is the "someone" you cannot prove is now trying to KILL YOU and everyone around you.
BTW any reasonable cop should consider that to be attempted murder. (unless you're just a whining punk)
I'm sure his police cruiser loses wheels on a regular basis and he just laughs it off while calling for a tow truck?
#1908
#1909
#1913
Re: Engine cranks in any gear?
It's my job to tell you it's broken, the government mandated safety starter interlock feature has been defeated disabled bypassed or broken and SHOULD be fixed correctly. The next decision is all on you. Congratulations your car is now in about 1986 safety standards.
I'd at least want to know exactly why it was done and know how well it was done. I wouldn't want a hairpin bypass jumper to fall out on a bump and not start on the next try.
#1914
Update: It is in the fusebox. I checked for continuity between the 2 load side terminals on the fusebox, and there is continuity even with the relay out. But now that I messed with the relay, it won't start at all weather the relay is in or out and there is no longer continuity between the 2 load side terminals on the fusebox. Ever see a fusebox fail in this way?
#1917
#1918
#1919
Rep Power: 97 Re: Easiest way to change a trans?
i should have taken my own advise.
i'm currently installing a stage 5 clutch.
I should have pulled the engine and tranny.
Not much room to maneuver with the transmission still in the car...
