Does the downstream o2 sensor effect anything? - Honda Civic Forum
LinkBack Thread Tools Search this Thread
Old 12-05-2017   #1
D17VTECPOWER's Avatar
D17VTECPOWER is just really niceD17VTECPOWER is just really niceD17VTECPOWER is just really niceD17VTECPOWER is just really nice
I have heard from a friend’s tuner that the ECU will freak out and run rich if the post cat o2 sensor is missing. Is that true? I thought that the entire purpose of the downstream o2 sensor was to make sure that the cat is working? I didn’t think that not having a downstream o2 sensor would effect the car at all besides causing an engine light. Who is right?
D17VTECPOWER is offline   Reply With Quote
Old 12-05-2017   #2
Allow me to explain through interpretive dance
Re: Does the downstream o2 sensor effect anything?
Quote:
Who is right?
Maybe neither.
ezone is offline   Reply With Quote
Old 12-05-2017   #3
Quote:
Originally Posted by ezone View Post
Maybe neither.
What do you mean?
Old 12-05-2017   #4
Missing, or inop/dead/numb/no-fouler installed?
Depends on how the engineers programmed the original control unit and the strategies they intended it to use.
One design may be affected minimally if a sensor is numb, another design may be greatly affected.
If a TUNER is doing it and they can't make the processor ignore the rear sensor input....what does that say?
Cat monitoring may have been an original design intent while OBD2 was being dreamed up and hammered out, but that's not the only thing going on.
Engineers design these things with emissions control FIRST, the idea that the first function of the engine and all fuel controls is a life support system for the catalytic converter. The engine just happens to pull the car around in the process.
Rear sensor can have a lot of influence over fuel trim values and strategies. The newer the car, the more important it is.
Even a cat fault code can cause a large drop in fuel economy on some cars.
Old 12-05-2017   #5
My 2005 Civic is missing the downstream o2 sensor and has no cat. If I get a junkyard downstream o2 sensor and install a defouler, will the car run better, worse, or no different?
Old 12-05-2017   #6
Quote:
If it works fine that way for you and you're ok with the CEL on all the time, DFWI.
Probably no real noticeable difference in how it runs, but the ECM or PCM will continually attempt to run the cat monitor self testing as long as there is no fault code for either O2 sensor....
Do you know how that cat testing is done?
By manipulating fuel controls.
Old 12-05-2017   #7
The Dongerator
Megalodong's Avatar
Megalodong is a splendid one to beholdMegalodong is a splendid one to beholdMegalodong is a splendid one to beholdMegalodong is a splendid one to beholdMegalodong is a splendid one to beholdMegalodong is a splendid one to beholdMegalodong is a splendid one to beholdMegalodong is a splendid one to beholdMegalodong is a splendid one to beholdMegalodong is a splendid one to behold
I tried the same setup with a 6th gen I owned a few years ago. I used two spark-plug defoulers piggy-backed as described in this thread: https://dodgeforum.com/forum/2nd-gen...t-removed.html .Had car for 10k miles afterwards and the CEL never came on again for secondary o2 code.
Didn't seem effect performance in any way.
Megalodong is offline   Reply With Quote
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
All Content Copyright 2017 CivicForums.com
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
