Check Engine - hesitates at 3000rpm on rainy/ humid days
Rep Power: 0 Check Engine - hesitates at 3000rpm on rainy/ humid days
I have a 2006 Civic EX sedan, I installed a cold air intake soon after i purchased the vehicle. About 2 or 3 times a year, on rainy days, the car hesitates (stutters) as soon as i hit 3 grand, and the check engine light comes. And the problem persists for a few days after. Then its back to normal. Anyone have similar issues? Thanks
Rep Power: 166 Re: Check Engine - hesitates at 3000rpm on rainy/ humid days
Is your filter clean?
And i remember my cousin's s2000 was doing something like this and it turned out to be a dirty vtec solenoid.
Rep Power: 787 Re: Check Engine - hesitates at 3000rpm on rainy/ humid days
did you ever see what the engine light was for? sometimes, enough water gets thru the air filter and can temporarily screw with the MAF sensor in the intake pipe, which can then give false readings to the ecu and affect the a/f ratio.
Rep Power: 0 Re: Check Engine - hesitates at 3000rpm on rainy/ humid days
I think the air sensor is reporting water. AEM is adamant that slight moister could not be causing the problem. I can drive through a monsoon and it is fine. Or a fog can affect it. I going to get it checked this afternoon.
1 Post
Rep Power: 328 Re: Check Engine - hesitates at 3000rpm on rainy/ humid days
yea, water is getting in. and it can cause serious problems...its called a hydrolock.
there is a hydolock by pass that AEM sells. look into that.
Oh wait you actually have a true cold air intake that goes all the way to the bottom of your motor. If so then yes hydrolock could be the problem. If its a short intake then a little rain should not cuase hydrolock unless your runing over giant puddles of water and have no splash cover.(the one that covers the bottom of your motor)
can you convert to a short ram? to be honest you will not notice any difference in power.
No vtec. Just the EX. Is there something similar do you know? AEM has recommended a filter cover to help keep out any moisture. Not sure, but will try anything. Thanks
This will sound wierd but I had a friend that had a similar issue on rainy days. Turns out the timing belt cover was letting moisture in and affecting the rubber belt. Once he changed the timing belt and sealed up the TB cover with a proper gasket, the issue went away.
thana
06-15-2020 07:05 PM
tylerginevan
04-27-2015 12:29 PM
dragonsblood
04-27-2015 12:28 PM
dooner24
04-14-2015 07:51 PM
