Shifting Without the clutch
Old Apr 22, 2002
Travii's Avatar
Travii is an unknown quantity at this point
I was having fun in my car the other day, and I found out that if you Match the RPMs in netural, as it would be in gear it easily goes into that gear no grinding. I was woundering if anyone who knows a lot about trannys, knows if this is bad. I know in theory it shouldn't hurt but I was wounding if I just didn't know something.
Old Apr 22, 2002
mwwhonda's Avatar
mwwhonda is an unknown quantity at this point
my dad used to do that in my accord all the time....i dont have the ***** to try it......and no, its not bad for the tranny if you know how to do it correctly.....big truck drivers do it all the time as well to save wear on the clutch.....peace
Old Apr 22, 2002
h2k1ex's Avatar
h2k1ex is on a distinguished road
Doesn´t seem too harmful, but I really don´t know. I´ve done it before and if you mess up you can grind the gears....... not good.
Old Apr 22, 2002
crazyjetskier's Avatar
crazyjetskier is an unknown quantity at this point
yea ive heard about people doing this but ive always been to scared to do it in all of my cars
Old Apr 22, 2002
Travii's Avatar
Thanks. Its the easiest to do from 3rd to fourth because on the LX it RPM's almost exaclty match the speedometer.
Old Apr 22, 2002
RedDragon333's Avatar
IT is if you dont know what your doing personally ill keep with the clutch after all thats one of the reasons i bought a 5sdp was for the control
Old Apr 22, 2002
nonbiasjeepowner's Avatar
nonbiasjeepowner is an unknown quantity at this point
Yeah like eveyone has said it won't hurt the tranny if done right, just make sure you shove it into gear, don't hesitate and gently put it into gear thats when you'll grind the gears.
Old Apr 22, 2002
01civic911's Avatar
01civic911 is an unknown quantity at this point
all the muscle cars back in the 70's used to always shift without the clutch, its called power shifting. cars with more power its ok to do it with, but with a civic, id say its a little risky. if youre racing the rpm's its not like you're being lazy, so why not pop the clutch in? thats half the fun anyways. I would say it isnt horrible, but by no means would i make it a regular thing to do.
Old Apr 22, 2002
EEdoza's Avatar
EEdoza is an unknown quantity at this point
Wait how is it that this works? You match the rpms to what? I wanna try this and then ill let everyone know how my experience went! Hopefully good!
Old Apr 22, 2002
BAK's Avatar
BAK
BAK is an unknown quantity at this point
It's when the syncronizers in the tranny sync (line) up at a certian RPM allowing the shifting of gears without a clutch and it's not good on finely tuned transmissions like ours.
Old Apr 22, 2002
To try this yourself it actually is pretty easy as long as you know what rpm's your engine is at at certain shift points. While shifting up through the gears theres nothing to worry about b/c when you shift up the rpm drops due to the gear ratio. When down shifting you need to rev the engine to the rpm the enigne would be at after the downshift, or at least resonably close to what it would be, it would be safer to go higher then you think you need to be. Good Luck
mrohitredd
40
Sep 9, 2017 12:03 PM
JetsterDajet
Aug 15, 2015 08:07 AM
f575gtc
Transmission
Jul 13, 2015 09:16 PM
Jul 12, 2015 11:54 AM
Steinar.D
Transmission
Jul 10, 2015 01:38 AM
