this maybe a noob question...
Old Mar 2, 2002
SuziQ's Avatar
SuziQ is an unknown quantity at this point
and i didn't do a search either![IMG]i/expressions/face-icon-small-tongue.gif[/IMG]
the question is how come the fact that we have a returnless fuel system a bottle neck in civic performance, especially when talking FI. from what i understnd is that a conventional system has a return line to the tank and the pressure regulator after the the fuel rail. whereas on a returnless sytem the fuel pressure regulator is near/in the gas tank (:confused[IMG]i/expressions/face-icon-small-wink.gif[/IMG] and the returnline is before the fuelrail and after the fuel filter (or is there no returnline at all. so how is this a problem that new injectors or new pump won't fix?
Old Mar 2, 2002
NeoMagus's Avatar
NeoMagus is an unknown quantity at this point
I have no idea as well, just heard that it may hinder the FI, since older civics have the return line....but im no Turbo guru so I couldnt tell ya
Old Mar 2, 2002
SuziQ's Avatar
thanks for the reply i think i figured it out. In the conventional system pump sends gas up to the fuel rail, and to maintain the proper pressure, a fuel pressure regulator on the rail bleeds off fuel as needed. So to go FI and put more gas into the cylinders all you need is an adjustable FPR (fuel pressure regulator) if your pump is strong enough. Whereas in the returnless sytem having an adjustable FPR is essentually useless b/c the it is near the gas tank. so the ECU has to determine how much gas goes into the cylinders by changing the injector pulses. wow i solved my own problem![IMG]i/expressions/laugh2.gif[/IMG]
Old Mar 2, 2002
SpdRcrChk's Avatar
BOOST JUNKY
SpdRcrChk is an unknown quantity at this point
<< thanks for the reply i think i figured it out. In the conventional system pump sends gas up to the fuel rail, and to maintain the proper pressure, a fuel pressure regulator on the rail bleeds off fuel as needed. So to go FI and put more gas into the cylinders all you need is an adjustable FPR (fuel pressure regulator) if your pump is strong enough. Whereas in the returnless sytem having an adjustable FPR is essentually useless b/c the it is near the gas tank. so the ECU has to determine how much gas goes into the cylinders by changing the injector pulses. wow i solved my own problem![IMG]i/expressions/laugh2.gif[/IMG] >>
Hey Suzi. Wish I would have come on earlier to help you with your question. I learned myself, recently, that a FPR is kinda pointless in our cars. So is an MSD...and obviously spark plug wires. Ina way it's kinds cool cuz we dont have to waste $$ on things that other cars might need before adding FI. It kinda works out good in a way.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
wootah88
Jul 21, 2015 10:22 AM
jmdcivic
May 20, 2015 09:52 PM
Tarbris
Electrical
May 3, 2015 09:51 PM
Mex
May 27, 2002 08:17 PM
