Heads Up Displays (HUD's)
#32
Rep Power: 250 The GM ones that I've seen are kinda hard to see when there's glare on the windshield....Not too sure about the aftermarket ones
#33
7thgens official a$$hole
Rep Power: 355 the more guages and stuff the better, but not really a huge fan of an ebtire HUD, expecially tachs there just not as accurate as a needle, due to the fact that its all led's. there always a frac tion of a second behind.
#36
Originally Posted by SIinthesky
When I do this mod I will be cutting a rectangle shape out of the dash and I will be using a peice of lightly tinted plexiglass to make it look ultra clean and OEM. Should look pretty good.
#37
#40
Rep Power: 0 When are you planning on doing this. You should make a good DIY for this project! Really the new ones on the vette are actually pretty easy to see during the day. I've only seen one occasion where there was a problem seeing it and we guessed that it was due to the sun being at the exact angle where it shined down into the unit and made it go away for just a second, then came right back.
Dean Walker
07-07-2015 02:27 PM
robbie374
07-07-2015 02:56 AM
08, aftermarket, automotive, civic, description, displays, glare, heads, honda, hud, hybrid, oem, photos, remove, sun
