Question about 02' 03' HONDA Civic Coupe DX models........
Old Dec 16, 2004
DMB's Avatar
DMB
DMB is an unknown quantity at this point
Exclamation Question about 02' 03' HONDA Civic Coupe DX models........
Okay..... I bought a fairly new (USED) 2002 Honda Civic Coupe DX model. Hardly any miles on it, and it runs decent. Just have 2 questions maybe some of you people could help me out on.....
1) When I have my fan kob on the bottom all the way to the left in the 'off' posistion, I still get lots of air flow through the vents on the console blowing on me.... the faster I go, the more air who blow out...... if the **** for fan is on off..... then why is all that air coming through?, is this normal?
2) The car doesn't have A/C...... So I was wondering how much trouble it would be, and how much it would cost to put an air condidtioner in the car....
thanks for your help .....
Old Dec 16, 2004
nindoo's Avatar
Why is my vagina bleeding?
I think it would cost too much to put in a AC and it wouldn't be as reliable as stock.
Old Dec 16, 2004
DMB's Avatar
DMB
is the air flow thing normal in your civic coupes?
the dealership near me said it would cost $700 to install it in the car........... I don't know if they are fooling me..... I know it's alot of money.... but I want to spruce the car up alittle.
Old Dec 16, 2004
vipergtsr's Avatar
vipergtsr should not be trustedvipergtsr should not be trustedvipergtsr should not be trustedvipergtsr should not be trusted
Is the air that you are talking about coming out of all the vents? Because the far left and right vents you can close. To my knowledge, when I dont have the recirculate feature turned on, it vents air in from outside. If the recirculate feature is on I get no air flow. I have an ex with air conditioning, so I don't know if you have this recirculate feature. It is the far left button under the radio looks like an arrow going in a circle. As far as adding a/c to your car, the company I used to work for installed aftermarket a/c units in all kinds of cars. There has to be a demand for the a/c kit in the aftermarket workd first, If there is low demand then no company is going to make a new kit. I do not know if there is a kit for our cars. Check with the dealer to see if the know of a company that installs aftermarket a/c. I costs like $1600-$2000. It isn't cheap.
Old Dec 16, 2004
DMB's Avatar
DMB
Yes, I close the left and right vents, but you can't close the vents above the console..... I find it hard to friggin' breathe when the re-circulation button is on.... WHat do people use that button for anyways....... It's just annoying when I'm driving 60 mph, and have my fan off, I got to get warm, or cold air blowing on me..... just a strange feature.
The dealership near me said $700 to put it in...... I'm hearing two different things now....... I mean, it can be done.
Old Dec 16, 2004
SmiteSwift's Avatar
SmiteSwift is an unknown quantity at this point
The recirculate button is used if you actually HAVE air conditioning and you want to recirculate the already COLD air inside the car on a hot summer day. But since you bought a DX . . . well
Old Dec 16, 2004
DMB's Avatar
DMB
understandable....... and many people have DX's...... but that's why I also asked how much you think it would cost to put in a A/C in the car.......
Old Dec 16, 2004
HondaSales's Avatar
HondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of light
a dealerships "cost" to put a/c in your civic is $1,212.25 which includes parts and labor. so, you should expect to pay a little more than this.
Old Dec 16, 2004
nindoo's Avatar
I guess there needs to be a little air flow, there a bit of wind noies in my car.
Is it really hot where your from? Cause I only use the AC when I use my defroster(case it comes on automatically) and on long trips. Other than that I like to drive with the windows rolled down.
Many people have told me that it isn't as reliable as the AC from the factory.
Old Dec 16, 2004
manthatguysfast's Avatar
How many pots have you smoken?
manthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of light
ya know there is a way to have full control of the AC. try this:
-Turn Car Off
-Turn Temperature **** To Full Blue (All the way to the left - Counter-Clock Wise)
-Turn Vent **** To Off (All the way to the left - Counter-Clock Wise)
-Hold Down Air Recirculation Button As Well As A/C Button
-Keep Both Buttons Depressed and Start Car
-Keep Both Buttons Depressed for 7 Seconds
-*AC LIGHT SHOULD BLINK*
You will now have control of your A/C regardless of what setting you are in, to revert back, simply repeat the procedue
Old Dec 16, 2004
DMB's Avatar
DMB
nice
Old Dec 16, 2004
nindoo's Avatar
-Turn Car Off
I tried it a few times and didn't work. I'll try again. Does it work on all 7th gen vics?
Old Dec 16, 2004
EL-Sport's Avatar
EL-Sport is an unknown quantity at this point
This is normal. I notice that I can drive on the highway with the heater off and I will still get some heat coming out of the vents when I'm driving at highway speeds. When stopped or moving at slow speeds there should not be anything coming out of the vents though.
Old Dec 16, 2004
chicohonda02's Avatar
Since 2002 Baby!
it get the same thing with air flow on my DX, bud. Not sure if thers anything you can do. Onthe A/C $700 is about right, I've heard higher, but, start looking around, you can pick up an A/C system like on ebay every once in a while for cheap. then go have it installed at Honda. Besides that there you go. Welcome, since you're new around these parts. And thanks for choosing DX, we are some of the rare ones aroud here. You will find everyone has everything, but rare DX's. Well i have a DX if you haven't noticed.
Old Dec 16, 2004
Jeff B's Avatar
Jeff B has a little shameless behaviour in the past
-Turn Car Off
NICE! I was thinking of just totaly disabling the A/C because I hate it when the A/C is on with the defroster and then I put the heat on so it completly counter acts the A/C. I am glad you said something about that...
Old Dec 16, 2004
Jeff B's Avatar
It took a few times to get it to work, but I got it figured out. You have to have the key in the ON position when you first push the recirc. and A/C then you start it and hold both till the A/C light goes green, NOT when the recirc buttom blinks.
Old Dec 16, 2004
nindoo's Avatar
^^^Cool I'm gonna try that
Old Dec 17, 2004
DMB's Avatar
DMB
so I guess that's the way it is.... deal with the air....... gotcha.
Old Dec 17, 2004
Oishi's Avatar
Oishi is an unknown quantity at this point
it is designed like that...when you have the windows down a little bit will cause the air blow more...very handy especially during winter...since the heater is too hot
miatabro
Jul 17, 2015 12:12 PM
Pr0n1s
Apr 30, 2015 03:08 PM
Civicman92296
Apr 23, 2015 09:22 PM
jessicakaybby
Apr 20, 2015 12:11 PM
Killagi
Apr 12, 2015 10:42 AM
