LX civic's
Old Jan 10, 2004
Marcus's Avatar
And Pimp I got the Juice
Marcus will become famous soon enoughMarcus will become famous soon enough
LX civic's
Can anyone from the site with a LX civic that upgraded with a turbo if there is a difference from 0 to 60,or just 60 to 100. Obviously there must be a quit a bit difference from 60 to 100. Just for the heck of it I;m curious of what u Turbo charged guys have left in the dust. The reson why I'm askin these ?'s are because I'm going to upgrade with a turbo, because my engin sucks.
Old Jan 10, 2004
civicvtec1ps's Avatar
Search and Learn
Search for "turbo"
http://www.7thgencivic.com/forums/fo...?s=&forumid=79
http://www.7thgencivic.com/forums/sh...hreadid=133270
http://www.7thgencivic.com/forums/sh...hreadid=107201
http://www.7thgencivic.com/forums/sh...hreadid=129441
Old Jan 10, 2004
Marcus's Avatar
Sick man thanx
Old Jan 10, 2004
huyqvu's Avatar
huyqvu is an unknown quantity at this point
u would benefit more if u save a couple more thousand and get a k20 motor swap which has more potential, unless you are satisfied with sitting at 160whp.
Old Jan 10, 2004
CuRiOuSfIsH's Avatar
Back From The Banned!
WHich kit gives 160HP to the wheels?
Old Jan 10, 2004
ebound's Avatar
ebound is an unknown quantity at this point
wtf?! i'm hoping youre sarcastic.
catalyst has a LX with shitloads more whp than 160 with his turbo, I think it's something in the low 200s; i'm not too sure, and keep in mind, that's with a dyno -- getting some nice cool air running through the FMIC should boost the hp even more. He runs around 13.6 at the track, which isn't bad at all for a SOHC 1.7 liter engine.
Old Jan 10, 2004
huyqvu's Avatar
sorry if i wrong, but i did see catalyst post that his car made 166whp not sure but maybe stock
http://www.7thgencivic.com/forums/sh...11#post1168911
and reading his post on his car being dyno'ed he stated "I made 200 ft/lbs at 3,800 rpm" and nowhere did it state how much whp.
Old Jan 10, 2004
civic01vtec's Avatar
on that run he had his head PnP'ed and his clutch let loose 3,800 rpm when it made 200 ft/lbs of torque. He is installing a new clutch and is expected to make around 270-280 hp. He did manage to make 235 hp at 3,800 rpm's.
You will benefit more from boosting the D17 than swapping a K20. The only way the k20 will be better is if you put another 5 grand on top of it into a all-motor set up or boost it. The K20 is a high reving motor which results in low torque. Only about 140 ft/lbs.
A stock EX at 8psi was dyno'ed at 183 hp and 189 ft/lbs of torque.
jonavin
73
Oct 4, 2004 07:18 PM
locozoko
Apr 6, 2002 09:00 PM
silvervtec01
Nov 4, 2001 06:56 PM
locozoko
Nov 4, 2001 05:45 PM
WeRkX
Nov 1, 2001 10:33 PM
