General 8th & 9th Gen Got a question or want to post but it doesn't quite fall under any other topic? Post up here!
06 Civic Sedan EX - AC not blowing cold air
Old 09-18-2018
marmayogi's Avatar
marmayogi is an unknown quantity at this point
Question 06 Civic Sedan EX - AC not blowing cold air
AC not blowing cold air, just barely cool. Checked with 4 mechanics and all 4 said compressor is failing and the high pressure is around 75 (should be 150-200) and low pressure is holding. Dye test was done, no leaks in system.
Question: should I change condenser, receiver drier, extension valve in addition to the compressor unit OR just compressor.
2 mechanics quoted me 600$ for an OEM compressor + Flush line + Freon + Labor. Another mechanic quoted me 1200$ for original Honda Parts (compressor + accumulator/drier + extension valve)
Bought the car brand new in 06 and have it maintained very good and its got 90k miles on it.
Old 09-20-2018
Ledward's Avatar
Ledward is an unknown quantity at this point
Re: 06 Civic Sedan EX - AC not blowing cold air
I am having the same issue with my '08 LX sedan and am very interested in what others' experience has been repairing the AC. Have any of you replaced only the compressor? What were your thoughts after doing so? Thanks!
Old 09-20-2018
The pressure looks like the compressor clutch isn't even engaging? Why or why not?
Clutch clearance, clutch coil, clutch relay, or thermal protector issue is expected.
I very rarely replace compressors because I almost always solve the problem with one or more of those parts I just listed.
investigator
47
08-07-2016 07:57 PM
G3rain1
07-17-2016 07:33 AM
Ggp9909
06-05-2016 09:28 PM
Ilikemscruffy
06-26-2015 09:51 AM
grambo82
05-28-2012 08:58 AM
Quick Reply: 06 Civic Sedan EX - AC not blowing cold air
