Problem with power windows
Rep Power: 0 Problem with power windows
I have 2006 honda civic . My windows wont go up or down within one click of the button i have to press and release the button again and again in order for the window to go up or down. Any solution? Also heres the link to the video i made of the problem
Click here
https://youtu.be/ra-WJFHpAPA
Click here
Re: Problem with power windows
Kind of looks like ether the window glass is binding or the switch is bad....or maybe the auto function was lost. Can't tell from your video which it could be.
When did this problem start? Shortly after windows were tinted?
You keep poking the switch
The drivers window switch button has 4 positions: Up, auto up, down, auto down
Will the window stay moving if you only move the switch to the up or down positions? (don't poke or pull far enough to reach the auto function)
You have tint and it sounds like the thing makes a lot of noise as it moves, the glass could be too stiff to move and the motor quits
Spray Silicone lubricant into the run channel seal where the edges of the glass must slide
If that doesn't help, I might want to remove the door panel to make sure the glass is not binding
QBoi
02-13-2005 07:19 PM
VRoomPSHeRt
02-07-2003 07:14 PM
adadani2001
12-31-2002 12:36 PM
