General 10th Gen Got a question or want to post but it doesn't quite fall under any other topic? Post up here!
Can you shift from D to S in a automatic transmission?
Old Aug 7, 2019
viviangrace's Avatar
viviangrace is an unknown quantity at this point
Hi everyone!
I have a 2019 Honda Civic Ex Hatchback, and I was wondering if there was a way to shift from D to S and vice versa while driving without stopping. I previously had a 2010 Honda Civic and I was able to bump the gear shift between D and D3 while driving with no problem, but whenever I tried to bump the gear shift in my hatchback it doesn't want to budge. Is it possible to shift? Or perhaps do I have to hold the button down when I shift now? (I didn't have to do that in my 2010 Civic) If anyone can help me with this I'll be super grateful!
Thank you!
Old Aug 8, 2019
Re: Can you shift from D to S in a automatic transmission?
To pull back to S, you'll have to push the button. You can bump back to D without it, however. You can switch back and forth without issue. The CVT in the 2016+ is different than that of the 06-12. 8thgen had a traditional AT with actual gears it shifted between. The 10thgen has a CVT which is just that: continuously variable
Old Aug 8, 2019
Would I be able to switch between them while driving as well? Or do I need to be parked?
Old Aug 8, 2019
You can do it on the fly. No harm in doing so.
Old Aug 8, 2019
Ok thank you so much I appreciate it! 🤗
Old Aug 8, 2019
No problem! I do it all the time since I have fancy pants paddle shifters in my '18 Sport hatch
Old Aug 8, 2019
That's probably fun to drive!
Old Aug 8, 2019
Absolute blast to drive, especially since I'm tuned to 21psi (from the factory 16.5psi) and have a bunch of other goodies installed on my car. Check out the "look how she's growing" link in my signature (or click here) if you wanna check it out
Old Aug 8, 2019
Omg sounds fun! I'll check it out!
Old Aug 30, 2019
sardaukar's Avatar
sardaukar is an unknown quantity at this point
How do you feel about the S (definitely not "Sport" mode) position on the shifter?
Old Aug 30, 2019
Definitely more up and go than regular D mode. Paddle shifters staying in gear as opposed to going back to auto-CVT mode after [x] seconds is kinda cool.
I use it infrequently, but when I need to get onto the freeway and maneuver out of the "pack", S mode definitely helps get me the f away from dumbass Vegas drivers
ocnwolf99
Jun 5, 2018 01:46 PM
1QUICKCIVIC
Oct 23, 2009 07:37 AM
Rambo2
Apr 22, 2008 04:20 PM
