2016 civic coupe Antenna Location
Rep Power: 0 2016 civic coupe Antenna Location
Anyone know where the FM antenna is located on a 2016 Civic Coupe Hatchback?? it has no shark fin on the roof and i can't seem to see any wiring in the windows anywhere and no whip anywhere on the body. Thanks in advance..
Received 1,144 Likes
Rep Power: 485 Re: 2016 civic coupe Antenna Location
Thread moved to correct subforum.
As for your question.. You're 100% positive there's no shark fin? I know it sounds like a dumb question, but I just took a look at parts diagrams for various trims of 10th gen coupes. All list a shark fin for an antenna.
p.s.
coupe and hatch are different, but both still use shark fin antennas
p.s.
...2016 Civic Coupe Hatchback??
We don't have a "coupe hatchback" in the US.
In 2016 USA there was only Coupe (2 door), and Sedan (4 door) models
USA hatchback (5 door) came along in 2017.
So it's a coupe......?
What trim level??
Antenna is either in the grid in the rear glass,
or if it has a fin on the roof it's in the fin on the roof.
What trim level??
Rep Power: 0 Re: 2016 civic coupe Antenna Location
p.s.
p.s.
What trim level??
What trim level??
Yes its a Coupe -- and has just 2 doors. if its in the Rear window -- would it be hard to get to the wiring or the plug connector without tearing out the Dashboard? Thanks for the reply.
What trim level is the car?
Which radio does the car have?
There's like 8 different trim/equipment levels and 4 or 5 different radios. I can't see your car to identify what it is or what it has in it.
What's your ultimate goal here?
Are you adding some accessory, or what?
since the front Glass was replaced - the radio reception has been very bad--- just trying to figure out where the antenna is to check connections if possible. It has a basic radio - no satellite antenna or anything fancy.. plain ole Music.
p.s.
p.s.
Remove the interior A pillar trim on the passengers side....there should be one antenna cable connector along that pillar, see if it got disconnected when the window was replaced
Reception comes and goes on intervals.
If the car is still under warranty, take it to your Honda dealer
Touge
03-23-2016 02:39 PM
dbailey
08-06-2012 10:44 PM
klam
08-14-2004 01:53 AM
