Brake Pads
Re: Brake Pads
Do you need brakes already? The car is only 4 months old. You can't possibly need brakes yet.
FWIW I work for a dealership. Honda brakes are always best for us.
Rep Power: 0 Re: Brake Pads
No, not on this one yet but for future reference. I will do front pads on Accord 2012 and Odyssey 2010 this weekend. Got OEM for Accord and Akebono for Odyssey. Been using only OEM pads in the past, this will be the first time on after market pads.
Re: Brake Pads
I lube the ears of the pad with moly grease, along with a light smear of the same between pad and shim and between layers of shims.
I don't like to put moly on the pad or shim that goes against the piston because it could attack the rubber boot.
NOTE: Moly grease eventually dries out.
If the pads were stuck in the bracket due to rust scale buildup I will remove the clips from the bracket and grind all the rust out, and clean up the clips as best I can. Apply dielectric silicone grease to the freshly exposed cast iron, reassemble the clips and make sure the pads are free to move now.
I also prefer dielectric silicone grease on the slide pins due to the rubber boots.
Pic of rusted caliper bracket before removing the rust
Thank you. Akebono pads came in two days ago and this is my first Akebono pads. Akebono came with Moly grease. I can tell you that the finished of OEM pad is much better and both were assemble in the USA. Been using CRC synthetic grease for metal to metal and 3M silicone paste slide pins and rubbers.
What so you think about CRC Synthetic grease to lube the ears and clips or should I use Moly grease that came with the pads?
Thank you,
Thank you,
Re: Brake Pads
Will it get runny at high temperatures and end up in places you don't want it to be? Moly won't.
Hondas pad sets come with the little packets of moly grease.
Akebono is a supplier to Honda.
Thank you. Yes, Honda pad came with black grease and I never use it because I didn't know it is a good grease but I will use it this time. Wow, I didn't know that Akebono is a supplier for Honda, so it must be the same material? I believe Honda pad is not ceramic but the one that I got for Odyssey is ceramic.
Re: Brake Pads
It's MoS2, Molykote, Depending on how runny it is I think they give us M40, M60 or M77
