Wheels, Tires & Brakes Modifications Post Wheel, Tire & Brake related modification information and/or questions here.
Bolt Pattern
Old 04-06-2017
2016Touring's Avatar
2016Touring is an unknown quantity at this point
Bolt Pattern
Just curious if anyone knows the bolt patterns for the 2016and up cars. I'm looking to get bigger rims and more sticky rubber.
Cheers,
Pete
Old 04-07-2017
Re: Bolt Pattern
Hondas small stud 5 lug cars, (06-up Civic, 03-up Accord, CRV, etc.), share the same bolt pattern, according to the (outdated) charts it's 5x114.3
https://www.discountedwheelwarehouse.com/Honda___Vehicle_Bolt_Pattern_Reference.cfm
Check out tirerack.com you can just enter your car info and have 500+ wheel choices to stare at.
Oh wait, you're in Canada....try this one: https://www.discountedwheelwarehouse.com/
Old 04-07-2017
The legs in the public bathroom stall
mcnoople's Avatar
mcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to behold
Re: Bolt Pattern
Oddly enough the 114.3 actually interchanges with the old 5 on 4.5" bolt pattern used since at least the 1960's on american cars. I was very surprised the first time someone told me about it. Just make sure you get rims with the proper sized hub diameter or get the appropriate hub rings to center the rims.
Old 08-17-2017
Re: Bolt Pattern
Thank you for the links I am looking at the 19's too 20's nothing too crazy just want to spice the look up a bit.
